Some tips on belt slip
I'm able to max out the S-Trim and push 12psi into a very free flowing 396 with no belt slip... and to do it, I did the following:
- Use the shortest belt that you can get on. In my case that's a 50.0", but with the original pulley that meant a 50.5" instead of the Vortech supplied 51.0"
- I added a Reichard Racing ultra-grip pulley ( http://www.reichardracing.com/ultra_grip_pulley.php ), and though I can't swear its a big benefit, it sure doesn't seem to be hurting.
I had dreams of a cog setup, going to 8-rib, and so on, but since I'm working the S-Trim about as hard as anyone here and doing it without belt slip, it's sure an easier solution!
Personally, I do not think the benefit of the ultragrip is what most think: it has slits in it that looks like they "grip" the belt, but I think that's negligible. I think its the fact that air under the belt has somewhere to go. You could probably achieve something similar by drilling air ports through an old pulley (but that might cause it to be structurally unsound and explode at 60,000rpm, so I'm not recommending it).
- Dave
The 3.125 is what mine came with.. so the 2.75 is what I would consider as a a smaller pulley....
I run the goodyear belt and I honestly think that it does grip better. I'm running the 3.125 pulley I'm running the older 7 groove, ( I buy the 8 groove belt and trim one rib off.)
As a side note I know Greg with Blowerworks is working on a 8 groove system.
I hope this helps,
Mo
Also, if you were using a stock pulley, you could glass bead blast it. I don't know about doing that with the reichard pulley since it's billet. I have a 2.85" reichard sitting at the house that I may try someday.
Getting 12 lbs out of an s trim isn't too bad. Heck, I"m having trouble getting 8 lbs out of mine on my 383.
How much boost are you guys seeing at about 4750 to 5000 rpm? I rarely get my car into high boost #'s in the 2 lower gears due to lack of traction and I don't want to be going over 90 on the street so I'm trying to figure out how much I'll see at redline when I run it at the track. I'm seeing 5lbs by 4000 and 7 lbs at 4750-5000 rpm. It doesn't seem like the boost is climbing much at that speed. Are you guys seeing similar boost #'s at that speed with your redline boost numbers of 10-12lbs?
With a 2.85 pulley you should be able to get a 50.0" on there, which is what I run.
For what its worth, I too run the Goodyear Gatorback belt.
You're right about the 50" belt. I would have swapped out the 50.5" but I didn't want to spend another 2 hours making the change. Next time I have the belt off I'll make the changes.
Mo
Here's a link to a thread with their setup on it. I wonder how I can get mine like that.....
http://forums.corvetteforum.com/show...ap&forum_id=86
