Not that I know about. The best way to use the FJO WB02 single channel unit that can log to a PDA. You can log the AFR rpm and 2 aux inputs such as TPS and MAP. This will give you the data necessary to quickly do VE tables.
The other way would be to use the New Tuner Pro 4 and Moates APU1 as that will also allow you to log an aux input in addition to all ALDL information. This setup would cost about the same as buying datamaster with the added benefit of doing tuning on the fly.
