dropping the engine back in, questions...
Old May 24, 2005 | 02:12 PM
350ws6's Avatar
350ws6
Default dropping the engine back in, questions...
I'm going to be reinstalling the engine from this thread into my 84. http://forums.corvetteforum.com/show...08&forum_id=48
Will it go in with the long tubes bolted on? Should I put in the distributor before I drop it in? Should I bolt up the flywheel/clutch/bellhousing first? Water pump and all accesories?
I've done a few engine swaps before, but never in a vette, just trying to get an idea of the easiest way to do things, thanks.
Old May 24, 2005 | 02:17 PM
ar91c4's Avatar
ar91c4
headers and accesories and distributor will not go in along with the motor.the water pump will.and my car is a auto but I believe on a standard you have to bolt the bell housing and clutch assembly on before installing.
good luck
