What's the difference between post/pre '87 heads
Old May 24, 2005 | 07:42 PM
hz900's Avatar
hz900
Default What's the difference between post/pre '87 heads
Looking at a set of aftermarket heads, but they are according to the part # pre '87 heads. Whats the difference and will it matter that much?
Old May 24, 2005 | 08:04 PM
JAKE's Avatar
JAKE
In mid 86, GM switched to aluminum heads on the Vette. Prior to that, they had iron heads, had press-in rocker studs, slots in the heads instead of guide plates, straight spark plugs (vs angle plugs), etc.
The combustion chamber volume may have been different too. I'm not sure if the very first aluminum heads took center bolt valve covers or, like all the earlier SB heads, perimeter cover bolts.
What are the specific heads you're considering? Maybe from that I'll know more.
Jake
Old May 24, 2005 | 08:39 PM
hz900's Avatar
hz900
Trick flow TFS- 30400001. I've got a 90 model.
I just ran across these today but I've got limited time to decide.
Otherwise I'll be buying dart pro 1's
Old May 25, 2005 | 03:41 AM
rodj's Avatar
rodj
I have the same heads.The only differences are the rocker cover monting bolt positions.
If you check their site
TFS- 30400001 is the same spec as TFS- 30400005
except the 005 is listed for 87 and laterifferent rocker covers.
I bought the cheaper ( more common ) ones and invested in a new set of covers.
Old May 25, 2005 | 03:45 PM
JAKE's Avatar
JAKE
Those come with small diameter valve sprngs that can only handle .520 valve lift, so I'd take a pass. Otherwise, if you opt to install a higher lift cam down the road, you'll be looking at changings springs too.
Is your engine reverse cooling?
Jake
Old May 25, 2005 | 06:48 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
I thought the differences were that the intake manifold bolt holes were drilled/tapped at a different angle on 87 on cast iron headed engines such as F-bodies, but remained at 90* for the vette L98 aluminum heads. However both F and Y body cars and most others for that matter also received centre bolt valve covers as well for 87.
If you have a 'stock' manifold, you will need pre 87 heads unless you elongate the centre holes on your intake manifold and either spot face it or use tapered washers under the bolts. You will still have the issue of the valve covers though.
I think they may well be perimeter bolt fittings.
However, it maybe worth checking with the vender as many after market heads now are drilled for both types of valve cover. They might just mean the intake bolts are pre 87. I think any will fit, you just might have to change things such as valve covers etc. ..Anyone else ??
Old May 25, 2005 | 10:14 PM
vader86's Avatar
vader86
In 86 when they switched heads, they went to center-bolt covers, so I'm not exactly sure what they mean by pre-87.
I guess they mean its meant for perimeter-bolt covers, thats the only change to the heads that might matter.
Usually they are drilled for both types.
To What's the difference between post/pre '87 heads
