how to tell magnesium?
Old May 24, 2005 | 10:26 PM
88421VETTE's Avatar
88421VETTE
Default how to tell magnesium?
How can I tell if the center piece of my BBS wheels are Magnesium. I know a few of the same style of wheels have magnesium centers. the centers look a little dark to be aluminum
Old May 25, 2005 | 01:57 AM
88421VETTE's Avatar
88421VETTE
Come on people no know how to tell the diff between aluminum and Magnesium
Old May 25, 2005 | 06:36 AM
Tom Piper's Avatar
Tom Piper
The best way I know to tell the difference is magnesium burns well if it gets hot enough, and if you add water, it burns better -- magnesium is used for underwater flares.
But, it would be a shame to burn your wheels to find out.
Tom Piper
Old May 25, 2005 | 10:36 AM
Nathan Plemons's Avatar
Nathan Plemons
A welding torch would let you know really quickly.
Old May 25, 2005 | 11:55 PM
88421VETTE's Avatar
88421VETTE
ttt
Old May 26, 2005 | 12:30 AM
1986Z51's Avatar
1986Z51
One non-destructive test would be to get some aluminum of equal weight and see how much water is displaced by each sample. Pure magnesium has a density of 1.81 grams per cubic centimeter and aluminum density is 2.68 grams/cubic centimeter so magnesium will displace more water.
http://hyperphysics.phy-astr.gsu.edu...buoy.html#arch
Old May 26, 2005 | 03:33 AM
skeet's Avatar
skeet
Why not call BBS?
Old May 26, 2005 | 07:50 AM
Tom Piper's Avatar
Tom Piper
Seriously, another way to tell, although not a convenient way, is to take the wheel and a piece of steel sheet metal and immerse them in salt water.
A simple one cell sea water battery can be made from two plates, one plate is magnesium and the other is steel -- the sea water is the electrolyte. This one cell battery will generate one volt.
If I remember correctly, the magnesium will be the anode (+) and the steel will be the cathode (-).
This single cell battery will slowly eat the magnesium away while working. So, don't use it to power a buoy for a month.
Years ago, I actually made a water proof fluorescent light (made from a circular fluorescent tube) that was powered from one of these single cell batteries. It used an inverter to step up the one volt to a level to power the light and germanium transistors (germanium saturation voltage is lower than silicon) for the inverter. Just throw it in the salt water and it would light -- under water.
Tom Piper
Old May 26, 2005 | 07:58 AM
tigmaned's Avatar
tigmaned
its pretty hard to tell, but one way if you have more then one hold them in each hand, and the mag one will be lighter then the AL ones.
Old May 26, 2005 | 12:57 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Many magnesium parts will be identified as such, say on the back.
Actually, there is a simple test. Apply a weak solution of Nitric acid to the material in question.
Any magnesium alloy will be blackened or turned gray by the solution, while an aluminum alloy will not be affected.
Larry
code5coupe
Old May 26, 2005 | 08:11 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Hmmmm the guy lives in Utah. Unless he's right near the great salt lake he's going to have a bit of a time finding "sea water" no?
Another idea might be to take a knife and see if you can slice a small sliver of metal off of the back of one wheel and then try the blowtorch test. Hopefully with a very small amount it will ignite fairly easily and not cause any problem.
Old May 27, 2005 | 06:40 AM
Tom Piper's Avatar
Tom Piper
I did say, "Not convenient."
Tom Piper
Old May 27, 2005 | 06:54 AM
88421VETTE's Avatar
88421VETTE
Actually we have the Great Salt lake has twice the percentage of salt as the ocean I think it's 6%. But my wheels have serial numbers and stuff on them I think I'll do some research
To how to tell magnesium?
