capturing ODBI codes real time 1993 LT1
Old May 25, 2005 | 12:48 PM
david350's Avatar
david350
Default capturing ODBI codes real time 1993 LT1
Is there a way to grab the engine codes while the car is running? I have a pesky code that only comes on while I'm on the highway (I suspect it might be EGR related). The code gets reset once the ignition is turned off. Help??? TIA
Old May 25, 2005 | 01:36 PM
Morley's Avatar
Morley
Scanner or laptop with scanning software and a cable to connect.
Old May 26, 2005 | 01:28 AM
Insane1's Avatar
Insane1
Read the codes with the car running just like you would read the codes with the car turned off.
To capturing ODBI codes real time 1993 LT1
