Cams
Old May 26, 2005 | 02:44 AM
fredk's Avatar
fredk
Default Cams
Is anyone running the TPIS ZZ409 cam, I need to know if it will pass emissions, and does the motor have to be tilted to install a cam in a 1993???
Thanks Fred
Old May 26, 2005 | 03:03 AM
rodj's Avatar
rodj
Don't have to tilt engine; have to remove radiator to get cam in from front.
Old May 26, 2005 | 05:23 AM
93 ragtop's Avatar
93 ragtop
I had to take a motor mount loose and raise mine to get the cam to clear.
Old May 26, 2005 | 07:22 AM
STL94LT1's Avatar
STL94LT1
,to clear the cross member.
Old May 26, 2005 | 07:26 AM
STL94LT1's Avatar
STL94LT1
Do you have the specs on the camshaft? From what I can remember it is fairly aggressive, and may be hard to pass emmissions.
Old May 26, 2005 | 10:32 AM
fredk's Avatar
fredk
Specs are 226, 226, .520, .520 lobe seperation is 112.
Old May 26, 2005 | 10:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
That may be tough to get to pass emissions. I've heard of guys doing it, though. Will be interesting to see.
Old May 26, 2005 | 11:11 AM
vader86's Avatar
vader86
I doubt you'll pass the sniffer with that cam in a good race-tune.
You'll need a program that costs you alot of power to get that one to pass.
Old May 26, 2005 | 11:29 AM
STL94LT1's Avatar
STL94LT1
With the right tune, you can get that cam to pass emmisions.
I'm hoping to get a 224/230 605/622 112 to pass.
Old May 26, 2005 | 11:39 AM
Nathan Plemons's Avatar
Nathan Plemons
It shouldn't be all that hard to make that cam pass. Street manners, partial throttle is completely different from wide open throttle in the tuning. Unless they make you test the car at WOT it shouldn't be any trouble to run a tune with both good performance and reasonable emissions.
To Cams
