these torques sound right
Throttle body bolts - 8 to 14
thermostat houseing 18-23
i did them both and just found middle ground, sound o.k. or should i take them closer to the high end of the torque?
Anywhere in the given range will work fine.
Larry
code5coupe
....but always be careful not to over-torque, as both the TB and WP housing are aluminum...
If you over-torque the throttle body bolts, you can tweak the butterflies so that they stick. This will cause an irratic idle.
If you over-torque the thermostat housing, it'll warp, leak and maybe even crack. Pep Boys, and probably other auto parts stores, sell a cast iron version of the housing for about $10.
Jake
thanks!!!
What are your other concerns?
Jake
First check that the MAF is plugged in. The connector is seen easiest with you standing on the passenger side of the engine; it's on the underside of the MAF. If plugged in, remove the MAF and check the very thin wires on the inside to see if one's broken. You'll need to look through the screens to see them. If one's broken you'll need a new MAF.
I'm not sure what a "deal" is. If you're referring to the torx head screw in the throttle body, then that's where you adjust the minimum airflow setting. Most find that 400 rpms is a little too low, so if you have idle problems, )engine stalling out, etc.) you may want to raise it to 500/550.
You need a digital volt meter to view and set the TPS voltage. I don't know what year your engine is. Some TPS can be adjusted, others can't.
If your TPS is the adjustable type, you'll see that it has three wires; top middle and bottom with the connector plugged in. A,B & C.
The simpliest way is to make three jumper wires, about 8" long each. Strip the insulation off all the ends. Then strip off a section of insulation at midway point between two of the wires. Those two will have to be inserted in the top and middle positions and is where you'll make your DVM connection.
Remove the TPS connector and insert on end of each wire into each TPS opening. The insert the other ends into the TPS connector BEING CAREFUL to insert the top wire from the TPS into the TOP opening in the connector, middle to middle and lower to lower. Clip you DVM leads to the two midway sections of the top and middle wire in the area you stripped.
Turn the ignition key to "ON", do not start the engine, then read the voltage. The voltage should .54 volts (plus or minus .075). Any reading between .615 and .465 is within spec. Most find .60/.61 gives better throttle response.
If an adjustment is required, loosen the two little bolts holding the TPS to the throttle body and move the TPS up to raise the voltage and down to lower it.
After setting the voltage, tighten the screws and recheck the voltage to make sure it didn't change in the tightening process. Now, reach over and slowly open the butterflies by using the throttle lever. Watch the voltage as you do this; the voltage reading should gradually rise as you open the throttle. There should be NO sudden jumps or dips in voltage. If you get any, the TPS needs replacing.
Anti-Lock problems won't set a code on earlier C4s, but since I don't know what year your engine is, . . .
Hope this helps.
Jake
