hooker longtube super comp
Old May 26, 2005 | 04:34 PM
1996man's Avatar
1996man
Default hooker longtube super comp
where is the best place to get these? i called Summit and asked them about theirs and if they sold a fitting to make them fit a LTx engine and he didnt know what i was talking about. So any help would be appreciated
Old May 26, 2005 | 04:44 PM
LT4-Z51's Avatar
LT4-Z51
The reason he didn't know what you were talking about was because hooker doesn't make long tubes for LT'S.I just went through this with jegs.Hooker only makes headers for the 84 - 91 C4'S.But they say you can make these work with several modifications to the headers for the emisions hookups.Or you can purchase TPIS headers that will bolt right on for around 900.00 dollers.
Old May 26, 2005 | 04:45 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Hooker doesn't make a Longtube header WITH AIR fittings that fits a LT-1.
People, like me, who have Long Tube Hookers do not have AIR injection installed on their cars. We have taken it off.
Old May 26, 2005 | 04:46 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
TPIS headers are not even close to $900 dollars and your claims about a 5rwhp gain is crazy too. Other than that you are correct.
Old May 26, 2005 | 04:55 PM
scorp508's Avatar
scorp508
From www.tpis.com .....
200-096 Headers, 92+ LT1 Corvette, Painted Without Emissions........$600.00
200-097 Headers, 92+ LT1 Corvette, Coated Without Emissions........$750.00
200-098 Headers, 92+ LT1 Corvette header, coated with Emissions.........$750.00
200-099 Headers, 92+ Corvette, Painted with Emissions.........$600.00
Old May 26, 2005 | 04:56 PM
1996man's Avatar
1996man
what is the AIR fitting? is that the only difference? do i need it? what happens if i get rid of it? is that the only difference? if i get rid of that can i install them?
Old May 26, 2005 | 04:58 PM
1996man's Avatar
1996man
i have heard a lot of good things about the hookers. is there any coated long tube header made for the LT engines that are less than 600 bucks?
Old May 26, 2005 | 05:04 PM
baumann95lt4's Avatar
baumann95lt4
i have a 95 and pickup up the headers built for the earlier c4.
they are hooker super comp 1 3/4" primaries not coated with no emissions control. The only thing that i had to do was pull the bolt out of the motor mounts and flip it around so that the nut was on the other side. other than that the headers had to clearance themselves by burning off some of the heat wrap around the stock motor mounts, but not so much that it would be a problem.
Old May 26, 2005 | 05:06 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
These questions have been answered a thousand times but here you go:
AIR are the ports going into the exhaust manifolds currently on your car. This is poart of the emissions system which cam on your car from the factory.
To remove this system is against the law and also you will not pass an emissions inspection if you have testing in your state.
I and others do not live in an emissions controlled state thus this stuff doesn't apply to me so I opted to go with the Hookers specifically made for a L98 on my LT-1. There are ZERO fitmit issues at all. ALL 350 chevy engines have the same spacing on the heads. There is no blockage over the LT-1 heads and there is not fitment issues with the body or frame. They fit perfectly.
When you remove the AIR system from you car you also have to get custom tuning to tell your computer it is gone. If you do not your car will throw a code and run like crap.
baumann95lt4
about those coatings...probably not, but polydyne is a company in texas that should be able to do it for $200 or less. They did mine for free to showcase for them...ask them about it. oh yeah and they will do just about any basic color that you want. and remember i am talking about a ceramic coating, not a powder coating.
Old May 26, 2005 | 05:10 PM
1996man's Avatar
1996man
and i take it the hookers made for the L98 dont come with AIR fittings? i dont have emmissions testing in my state but dont have tuning software so i gues si would need it
Old May 26, 2005 | 05:12 PM
baumann95lt4
the hooker super comps do not, you would have to have your car tuned by a RESPECTABLE shop. Do you know of any in your area, specifically with a dyno??
Old May 26, 2005 | 05:15 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
Hooker 2151 comes with no emissions equipment at all for the L98 or the LT-1
Hooker 2149 comes with AIR emissions equipment for the L98 specifically which is very useless for the LT-1.
Old May 26, 2005 | 05:18 PM
1996man's Avatar
1996man
guess hookers are out. are the tpis headers the only other way to go ? i have heard exotic muscle headers are nice but really expensive. what other headers do you suggest?
Old May 26, 2005 | 05:22 PM
baumann95lt4
why are you afraid to delete your emissions equipment? You don't have cats on the car right now, right?
Old May 26, 2005 | 05:26 PM
VR'92's Avatar
VR'92
St. Jude Donor '03
For someone who needs to keep emissions you should go with TPIS or EM. Honestly the quality is probably the same.
I would get some pricing info first. There usually is a GP on the EM headers so look for that on here. Scorp already posted some good links for the TPIS stuff.
Old May 26, 2005 | 05:28 PM
1996man's Avatar
1996man
cause i dont want to have to worry about getting it tuned before i can drive it if it will run like crap without that AIR stuff. i will get tuning software down the road but would like headers first. looks like i may go with TPiS i guess.
To hooker longtube super comp
Old May 26, 2005 | 05:31 PM
baumann95lt4
it wouldn't run that bad, and i would not recommend tuning or deleting or messing with the settings in the computer if you do not know what you are looking at. At this point a dyno tune might be good for your car. You ever seen your air/fuel ratio on a wideband???
Old May 26, 2005 | 06:00 PM
baumann95lt4
what...do you not believe me? I don't understand, i am trying to help you and save you money but you seem like you do not want to be helped. So if you are all set on this topic then let me know...if you need help let me know too..
Old May 26, 2005 | 06:57 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
First, I don't know about ealier LT1s but on my '95 removing the A.I.R. stuff caused no codes or any other problems. I did it when the car was still close to stock and it was fine then and is still so. I would think your '96 would fare equally well. EM has been having GPs on their headers about every three months lately, they're about due. The usual price on their LT1/4 coated headers is $771. During the GPs they are $671 plus around $30-35 shipping if I remember. They are very nice headers. I bought some during the winter GP but then shortly thereafter found these DRMs (no longer made) so I let a friend have the EMs. Nothing wrong with the EMs, I just liked the stainless headers better. EM also makes a stainless header but does not offer it as part of the GP.
