96' hop ups
Old May 26, 2005 | 04:38 PM
Darth Vader's Avatar
Darth Vader
Default 96' hop ups
Im thinking about racing this 1996 LT1 300 hp. auto coupe of mine with 16k miles against a new 2005 CTSV Caddy 400 hp. with 3k miles and a 6 speed.
The Caddy is 600lbs heavier. People say that it would be a close race or that the Caddy would win??
So are there any cheap cost effective ways to get a few more horses out of my 1996??? To tip the scales in my favor.
Old May 26, 2005 | 04:43 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Since your an Auto I'd say
1) Torque Converter
then
2) Exhaust
3) Roller Rockers
4) Electric WP
5) Cam
Old May 26, 2005 | 05:26 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
You have been on here long enough haven't you been reading?There are about a thousand threads on this subject.Do a search. I heard the TB airfoil is the best bang for the buck.
Old May 26, 2005 | 06:38 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
This is good for about 25Hp easy Ask any seller!
Old May 26, 2005 | 06:44 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
You know that tornado thingy is also good for at least 25HP and I've heard that if you use both the TB airfoil and the tornado the effect goes up the square of the diameter of the left side airfoil.
Old May 26, 2005 | 07:11 PM
Redeasysport
Oh I almost forgot cut up your air cleaner lid it is good for 10hp.
I did not know the LT1 had 300hp but with these mods you will be running 360hp easy.
lukeskywalker's Avatar
lukeskywalker
2nd Gear
Use the Force.
Old May 26, 2005 | 07:16 PM
Redeasysport
Atta boy Luke forgot that too. The darkside is much stronger these days.You lose not with the power.
Old May 26, 2005 | 07:38 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Originally Posted by lukeskywalker
Use the Force.
Quit pickin on yo daddy you foo!!!
Don't forget the electric superchargers that can be bougt on Ebay for $200!!! That's cheap forced induction!!!
I'd start with the torque converter... exhaust, headers, nitrous, more nitrous, even more nitrous, and some ET drags... you will hit the mark
Old May 26, 2005 | 10:18 PM
96dblblack's Avatar
96dblblack
Come on guys lets help him out here. He needs to tint the windows. The cool factor alone adds 50 horses.
Old May 26, 2005 | 10:27 PM
Redeasysport
Thats right everyone knows a cooler temp in the interior shinks the cockpit area lowereing the drag co-efficient. Up to 410hp with that gonna need a new rear end now.
Old May 27, 2005 | 07:49 AM
runner140*'s Avatar
runner140*
And T/B bypass (12rwhp).
Old May 27, 2005 | 11:22 AM
rayosequis's Avatar
rayosequis
On a serious note, keep in mind that the Caddy has an LS6 based motor which I believe were rated at rear wheel hp rather than crank hp like the LT1 motors. I have a friend that works at a performance shop here in Houston, and he dynoed several stock SS Camaro's that put around 300 at the rear wheels, so you can guess what it is at the crank.
As far as cheap mods go, it really depends on what you consider cheap. The above mentioned mods (TC, exhaust, RR) are not terribly expensive, but not easy to install yourself or cheap to have installed.
If you want to do a few things, do a Hypertech power programmer and a K&N airfilter as cheap start.
And good luck !
To 96' hop ups
