anti lock light no going out?
Old May 26, 2005 | 08:13 PM
tigmaned's Avatar
tigmaned
Default anti lock brakes dash light no going out?
sorry but i have few more problems i need some enlighting on?? when I turn the car on the anti lock light stays on all the time. i even did like the code reader said and it never blinks but justs stays steady?? whats that telling me or should i be afraid to ask??
Old May 26, 2005 | 10:54 PM
Arrest Me Red's Avatar
Arrest Me Red
Default ABS Computer
Ed: That is one sign of a bad computer. I had that issue with my '90. You should check the relays and all wiring in the area of the pump module. If you do a search, you may find posts on troubleshooting. In Vette or Corvette Fever within the last 2-3 years there was an article on how to check the relays. If you need a new computer, look on ebay, as well as this forum. I found a good one there at a reasonable price, about $100. Good luck.
Old May 27, 2005 | 12:59 AM
JAKE's Avatar
JAKE
First thing to check are two fuses, brake and gauges.
Then there are three relays on the ABS that should be checked. Then there is a high amp wire and finally a ground wire. Problem is usually caused by a bad relay.
I typed up a doc file fwith the anti-lock test procedure. If you want it, email me, jakejr266@sbcglobal.net and I'll send it to you.
Jake
Old May 27, 2005 | 06:16 PM
tigmaned's Avatar
tigmaned
were is the anti lock computer, behind the driver seat? i got worried when i looked under the passanger seat and found a big plug not going any were, could that be the anti lock hook up to its computer?
Old May 27, 2005 | 06:35 PM
dchildress's Avatar
dchildress
You failed to mention what year you have.
On my 94 when my ABS light comes on I wiggle my connections near the wheels for the ABS sensors. Seems to work almost everytime. Its free and easy. At least try it and the fuses before digging into the system.
Old May 27, 2005 | 10:21 PM
tigmaned's Avatar
tigmaned
sorry about that i have 1986, my anti lock light never goes out, even when i try to read the codes.
Old May 28, 2005 | 06:56 AM
tigmaned's Avatar
tigmaned
were can i find the abs computer? behind the friver seat too?
Old May 28, 2005 | 06:19 PM
JAKE's Avatar
JAKE
The 86, like mine, doesn't throw any ABS code; system's not designed to.
Look in the compartment behind the driver's seat for most of the things to check.
I already sent you the test procedure, did you receive it?
Jake
Old May 28, 2005 | 09:21 PM
JETSET's Avatar
JETSET
Default jack it
try putting it on jack stands at all 4's
then run it up to 30 mph and put the brakes on
see if the pump works then
mine is doing the same thing as yours with the light on
mine goes on after it rolls over 5mph
when i did it on the stands the light didn't go on and the pump worked.
So the back brakes and system works.
but when i drive it the light goes on in a few feet
i checked my front sensors and they had some greae on them
a no no
suposed to use anti seaze and only a little.
the hubs were replaced by the dealer and I found syrofoam ***** stuck to the sensor. I also found some stuck in the grooves.
not sure if that was the problem.
I checked the resistance at the plugs coming from the sensor behind the seat. The two 5 pins ones.
supposed to be between 900 and 1500
mine were 1025 or so at all wheels.
I also checked them after taking the sensors out while bending the wire around in the places the outer covering was cracked to see if the meter changed. This checks for intemitant problems with the wire.
Still trying to find my problem.
At least i heard the pump go on with the jack stand test.
So i know it is not that.
going to put it all back together ands try it again.
Old Jun 13, 2005 | 06:14 AM
tigmaned's Avatar
tigmaned
i checked the one relay thats off to the side and got power were i was suppose to, now i have the other two relays out, going to do the jump between pin 87 and 30. you know i don;t think i have ever heard my pump come on? but that could still be the relay right?
Old Jun 13, 2005 | 08:01 AM
tigmaned's Avatar
tigmaned
did the jump from pin 87 to 30 and with a test light and key on, my test light caming on but i didn't hear the pump? well i tried with just soem wire, and this time the pump came on so thats telling the relay is whats wrong i hope?
To anti lock light no going out?
