I need to remove some material from the underside of the plenum in the area of the EGR valve (Clearance issues with large tube runner install). How much material can I safely remove?
The plenum clearly sits lower with the large tubes than with the stock runners, thus the interference. 1/8" Just might do it, though. Jim @ TPIS says he's never run accross this before. Maybe it's just an oddball set of runners. Probably not much I can do with the EGR valve.
Are they the Accel runners? They are shorter than stock.
I bought them from another Forum member who claimed TPIS Part no. 500-503 which their catalog says is good for 85-88. The interference is at the top of the EGR valve / bottom of plenum. I'll do more investigation after the long weekend.
Can you lay them next to the stockers to see if the TPIS runners have a tighter radius?
All I can say at this point is that they are LONGER as measured along the outside radius of the tubes. I suspect a tighter radius would be tough to detect by eye, but the interference tells the story about the final height of the plenum.
Can't you just mate them up to each other?
For example, if you take a coffee cup and set it on the counter. Then take another coffee cup, turn it upside down and set in on top of the first cup.
Using one of each, align the bolt holes on one end and see if they still align on the other. Or try measuring the distance between one upper bolt hole and one lower bolt hole on the stock runners. Then do the same on the other TPIS runner. See if there's a difference.
I'm just brain-storming this problem trying to visualize a way to detect the difference between the two.
