Head porting
Old May 28, 2005 | 01:36 PM
jstkrsn's Avatar
jstkrsn
Default Head porting
I bought a used set of LT4 heads and am gasket matching the intake and exhaust ports. In my old "How to HotRod Small Block Chevys" book it talks about doing the same to the area around the spark plug on the exhaust side only. But not the intake side. This will reduce compression value. But is the overall performance gain a plus? I think this is what is done when you CNC a head isn't it?
Thanks for your help
Jim
Old May 28, 2005 | 02:27 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Both sides of the heads are worked.
Alot of power is found in just unshrouding the valves and removing some (not all) of the valves throat.
Old May 28, 2005 | 02:40 PM
500hp's Avatar
500hp
Quite often when heads are CNC ported, the head's deck is surfaced a few thousandths to retain most of its desired combustion chamber volume, depending on the amount removed during porting. The porter is able to accurately measure the chamber volume and target a specific compression ratio. If you plan on rounding off that hump and recontouring a small portion of the chamber, TPIS sells a thinner .029" headgasket that would increase your compression enough to prevent any loss in power from mild chamber porting. If you were to remove the valves and blend the 'pressed in' iron valve seat to the aluminum runner pocket, you would be making the most important improvement a stock GM casting needs for more flow/cfm.
Old May 29, 2005 | 11:38 AM
jstkrsn's Avatar
jstkrsn
Thanks guys
To Head porting
