After market wiring experience?
Old May 29, 2005 | 01:56 AM
Joer350's Avatar
Joer350
Default After market wiring experience?
Hi I have a question to see if any one here has gone with aftermarket fuel injection wiring like painless wiring and what the experince is to put one of those on?
I also got to see one up close( because i bought one to replace my buchered wires) and the wires that go to the injectors all become one wire from painless, so how is the ecm goin to know which one to fire? (meaning 2 injectors will become one for a total of 4 wires coming out of the ecm, then converting to 8 on the injectors)
Old May 29, 2005 | 02:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The injectors on an L98 are batch fire (ECM has only two injector driver ports) but I thought the LT1 was sequential fire.
Old May 29, 2005 | 03:20 AM
k99ja04's Avatar
k99ja04
No experience to the original post, but OBDI batch fire thru 93, changing to OBDI sequential thru 95 changing to OBDII in 96. \
I have been looking into swapping my 93 ecm to a say a 94-95 and is seems all aftermarket harnesses are not direct fit for corvettes, the work, but are intended for transplanting LT1 into hot rods for example.
Old May 29, 2005 | 03:30 AM
cmashark's Avatar
cmashark
i think i saw a post recently about a company that would rebuild your harness....give me a minute and i will find their website.
chris
Old May 29, 2005 | 03:32 AM
cmashark's Avatar
cmashark
here you go....
http://www.jimsperformance.com/
To After market wiring experience?
