speed bleeders
Old May 29, 2005 | 09:20 AM
the blur's Avatar
the blur
Default speed bleeders
any good speed bleeders out there for my 96?
I tried the ones in the "HELP" section, but the rubber bootie doesn't fit back on.
any one have speed bleeders ?
that work and fit properly?
Old May 29, 2005 | 10:14 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default I've used the "Help" ones
and they suck donkey *****. get these, they work:
http://speedbleeder.com/
Old May 29, 2005 | 10:29 AM
MYCoupe's Avatar
MYCoupe
I have a set of the SS speed bleeders on my car and so far they have worked just fine. Makes it so much easier to flush out the brake system when you're by yourself.
Old May 30, 2005 | 07:51 PM
MarkBychowski's Avatar
MarkBychowski
Old May 30, 2005 | 08:26 PM
the blur's Avatar
the blur
any body have them fail ?
I have heard reports of them failing.... stuck open !!
Old May 31, 2005 | 07:58 AM
Strick's Avatar
Strick
How many times have you used them and have you had any air leaks around the threads during bleeding?
Old May 31, 2005 | 10:33 AM
MYCoupe's Avatar
MYCoupe
I've used them probably 2 or 3 times (the front a few more). I haven't had any issues with them. I spent a little more (actually a lot more) on the SS ones because I had heard of the regular ones having issues with the check ball getting rusty over time and getting stuck.
Old May 31, 2005 | 10:50 AM
MarkBychowski
I've had the standard speedbleeders (non-stainless) on my factory calipers for about 5 years with no problems. I flush / bleed the brakes several times a year and have haven't had a problem. One of the keys is to not open them too far when bleeding. You only need to unscrew them 1/4 turn. If you open them too far, the threads can start leaking and cause air to get sucked back into the caliper.
Earlier this year I moved the front calipers to the rear and installed Wilwood 6-piston calipers. I just ordered stainless speedbleeders for those (just to be safe).
Regarding failure: If the checkvalves did happen to fail and stick open, it would just make them work like a normal bleeder screw. The seal is made when you tighten the screw all the way down, so there's no safety / brake failure issue.
Old Jun 1, 2005 | 01:42 AM
wake's Avatar
wake
I put them on my 96 last month... One thing that kinda freaked me out was the rear bleeder screws are shorter than the stock ones... It looked like it wouldn't seat far enough to seal, but it does at the very end, so don't let that throw you...
Get the original speedbleeders... They don't really cost any more than the copy cats you find locally...
Old Jun 1, 2005 | 09:09 AM
larryfs's Avatar
larryfs
which ones did you put on last month ?
the one that are too short won't hold the rubber bootie.
Old Jun 1, 2005 | 10:02 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
A Mityvac with the regular bleeders removes all the problems encountered with speed bleeders.
Old Jun 2, 2005 | 04:29 AM
wake's Avatar
wake
The speed bleeders will come with thier own boot that you use... The stock boots won't work with them... Yes, they are the ones I was talking about being shorter than the stock bleeders...
Your generic ones didn't come with a boot/cap of some kind???
Old Jun 2, 2005 | 04:43 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Just buy some little caps from the hardware store.
As for the bleeders, get a 10mmx1.0 die and remove that thread sealer **** they put on, and use teflon tape. The sealer they apply tends to harden making the bleeder not seat, or drops bits of sealer into the hole and plugging/jamming the bleeder, or just getting the damn thing crossthreaaded.
Old Jun 2, 2005 | 07:44 AM
CAJUN ZZ4
Guest
Posts: n/a
The best thing to do is re-install the originals after bleeding..don't have to worry about it. Normally only one wheel at a time is blead (s).
Old Jun 2, 2005 | 10:05 AM
OrthoAggie's Avatar
OrthoAggie
i tried speed bleeders when i did my C5 brakes and i could not get all the air out with them, i used them with a mityvac and got all the air out and fixed my soft pedal
Old Jun 2, 2005 | 10:13 AM
c4cruiser's Avatar
c4cruiser
As mentioned, the trick is to not open the speed bleeder too far. A quarter turn is all that's needed to get the fluid to flow out.
Speed Bleeder also sells a bottle of the coating that they put on the threads and they recommend that the coating be re-done after a dozen or so of opening/closing cycles. IIRC, it's about $10 for a bottle, but if it keeps the leaks away, it's probably worth it. I have not seen any problems with mine after about 10 cycles so far.
I've tried the Russell bleeders and they are nowhere near the quality of the "real" Speed Bleeder product.
Old Jun 2, 2005 | 10:49 AM
wake's Avatar
wake
Interesting... I didn't have that problem with either the Vette or my Caddy... Sure made flushing the brake system a breeze...
To speed bleeders
Old Jun 2, 2005 | 02:10 PM
pwrful c4's Avatar
pwrful c4
this is the way to go.
Old Jun 2, 2005 | 03:56 PM
luvmy92's Avatar
luvmy92
So do you have to hook up some kind of a hose with a container in order to catch the fluid coming out? How do you know if you have gotten all the air out if you can't see the fluid being pumped into the container?
Just curious as I am interested in these.
Mike
Old Jun 3, 2005 | 08:24 AM
luvmy92's Avatar
luvmy92
Mike
