Tail light problem
Old May 29, 2005 | 07:45 PM
vmdr's Avatar
vmdr
8th Gear
Default Tail light problem
When the headlights are turned on, the tail lights and parking lights don't come on. All four brake lights come on when using the brakes, but no tailights. Any idea why this might be happening? This is an '87 coupe.
Old May 29, 2005 | 09:57 PM
jfb's Avatar
jfb
If it were the front parking lights that go out with the headlights on, that would be caused by a poor connection to the single frame ground which all the front lights share. The rear lights all have a common ground, but much different (the grounds are near the lights) than the front light grounds so a poor ground is not the cause.
I believe that you have a defective headlight switch because when pulled to its first detent, only the parking lights come on and the next detent turns on the headlights in addition to the parking lights. The brake lights are on a separate circuit and not involved.
Old May 30, 2005 | 02:16 AM
vmdr's Avatar
vmdr
8th Gear
Alright, thanks a lot.
Old Jun 7, 2005 | 03:03 AM
vmdr's Avatar
vmdr
8th Gear
Default still no lights...
Update:
I intalled the new switch, but still no parking or tail lights. Since that didn't work, I have no idea where to go from there. Any help would be great.
Old Jun 7, 2005 | 08:29 AM
JackDidley's Avatar
JackDidley
Check the fuse for the dash lights. Seems like mine did this one time. In the daylight you dont notice the dash lights dont work.
Old Jun 7, 2005 | 10:12 AM
c4cruiser's Avatar
c4cruiser
Looking at the owner's manual, the olny fuse related to the lights is labeled as "TAIL" on the fuse block. It's a 10A fuse between the A/C and INJ1 fuses. It controls power to the headlamp switch (circuit 240).
The dash lights are controlled by a different fuse that protects the LCD dash assembly so it should still be working.
Old Jun 7, 2005 | 06:07 PM
vmdr's Avatar
vmdr
8th Gear
Fixed it. The fusewas the problem. I put a new one in and now it works. Yeah i know that should have been the first thing to check.... Thanks for the help.
Old Jun 7, 2005 | 06:55 PM
JackDidley's Avatar
JackDidley
At least it was cheap and easy. Did I just mention my ex ??
Old Jun 7, 2005 | 07:21 PM
okies93's Avatar
okies93
St. Jude Donor 06
your's too....
Old Jun 7, 2005 | 09:46 PM
petdoc's Avatar
petdoc
We all learn from this.... glad you found it!
To Tail light problem
