Bigger TB Gain?
Old May 29, 2005 | 08:10 PM
bigjack's Avatar
bigjack
Default Bigger TB Gain?
Can anyone comment factually on any gains thru going to the 52 mm throttle body ??? Thanks.
Old May 29, 2005 | 08:17 PM
Fubar569's Avatar
Fubar569
i cannot comment factually, but i can say this. in order to warrant a larger throttle body on any vehicle you must first have done mods to increase the airflow beyond the capabilities of the stock unit before you will see any significant gains. I.E. heads, intake, cam, stroker, etc... or you should be utilizing forced induction. I have seen several people run perfectly fine with a stock unit on a HIGHLY modified engine.
Old May 29, 2005 | 09:37 PM
Lone Ranger's Avatar
Lone Ranger
If you put a 52mm on a stock engine, the possibility exists that all you'll do is lose some low end torque. This is because without the engine NEEDING the extra breathing capacity you'll just slow down the velocity of the intake air charge in the manifold by using a larger than necessary diameter.
Old May 30, 2005 | 12:51 AM
vader86's Avatar
vader86
I wish people would say what YEAR and what theyve done or are planning to do to the car before they'd ask this question, since its been asked 10 million times.
In very few cases will it help a 350, doesnt matter if its LT1 or L98. I have seen a couple people with LT4's get something out of it, but then I recall many that havent. The engine cant use all that the stock 48 supplies anyway.
Old May 30, 2005 | 03:21 AM
cplonner's Avatar
cplonner
i have a stock throttle body on my 86' and i have bigger runners, base manifold, vortec heads and a medium cam. car runs decent right now. i am debating on weather i need one, and im gonna try to do the math to see if i can use the extra air flow. it might be a while before i get it but when i do i will let you know!b
Old May 30, 2005 | 02:43 PM
MacVette86's Avatar
MacVette86
My stock 48mm throttle body was shot, so I'm replacing it with a 52mm from TPIS. I have to replace the TB, so I might as well do the 52 as I plan to do intake modifications down the road. However, if my stock TB was still good, I wouldn't replace it.
To Bigger TB Gain?
