clutch problem
Old May 29, 2005 | 08:27 PM
slick50's Avatar
slick50
Default clutch problem
how exaclty can I figure out where my hydraulics are failing for my clutch system? I have been spending hours tring to figure this out. Is there a way to do this without replacing every part?
Old May 31, 2005 | 07:53 AM
slick50's Avatar
slick50
Anyone? I totally stumped
Old May 31, 2005 | 08:15 AM
LD85's Avatar
LD85
Take the slave off of the car but do not disconnect the hydrualics.
Have someone push on the clutch pedal while you depress the slave rod,, if you can hold the slave rod from moving then it is the master cylinder.
If you have fluid leaking at the slave, then it is the salve.
To clutch problem
