simple rocker arm question
Old May 30, 2005 | 03:33 AM
cplonner's Avatar
cplonner
Default simple rocker arm question
can your rocker arms change the lift of your cam?
i have vortec heads and the max lift is .480 , what parts limit my lift? what can i do to upgrade the heads for a higher lift?
Still learning about this stuff, thanks if you can give info!
Old May 30, 2005 | 03:41 AM
Morley's Avatar
Morley
Going to 1.6 rockers will give you about 0.030" more lift at the valves.
If your current cam is .480" lift now you'll end up at .510" (or there about). If you have stock vortec heads you'll probably need different springs, and you had better get screw in rocker studs.
Old May 30, 2005 | 09:51 AM
cplonner's Avatar
cplonner
so that means a decent gain in horse power with the added lift?
and just studs and springs is all i would need to make the heADS support the higher lift? sorry about so many questions!
Old May 30, 2005 | 10:08 AM
CFI-EFI's Avatar
CFI-EFI
After you shim the springs for the proper seat pressure, be sure to check for coil bind at full lift. You will also want to check for valve spring retainer to valve guide/seal clearance, and valve spring retainer to rocker arm clearance.
RACE ON!!!
Old May 30, 2005 | 10:12 AM
Pete K's Avatar
Pete K
I agree with the posts. Anytime that you change the factory valvertrain parts or geometry, you must check everything. Aftermarket rockers are sometimes known to rub on the edges of the spring retainer also.
Old May 30, 2005 | 10:15 AM
8388's Avatar
8388
St. Jude Donor '14
take your lift .480 and divide by 1.5 = .320 then multiply by 1.6 = 512
Old May 30, 2005 | 04:01 PM
ZD1's Avatar
ZD1
for the vortech heads your limiting factors are the rocker stud and the valve springs. As stated measure for valve spring clearance...but also look for the maximum lift rate. These heads probabley won't handle the fast ramp rates of roller cams.
The press in rocker studs limit the valve spring rates-thus RPM and or max lift.
In MY opinion don't look at anything beyond the lt4 hot cam (moderate lift and slow ramp rates)
good luck
btw what intake are you going to run?
Old May 30, 2005 | 04:34 PM
JAKE's Avatar
JAKE
I'm surprised that CFI-EFI didn't jump right on this one. LOL - Just thought I'd have a little fun.
No, changing rocker arms doesn't change the lift of the cam. The cam lobe lift remains the same.
What they do is change the amount and rate the valve is lifted off its seat. In other words, the valve is lifted higher and quicker when you swap from 1.5 to 1.6 rockers. Now, if you go the other way, change from 1.6s to 1.5s, the reverse occurs.
1.6 rockers also increase effective spring open pressure, because the springs are being compressed about .030" more. Many times, this increase in open spring pressure will cause press-in studs to pull out.
To switch to screw-in studs calls for pulling the heads to have the stud bosses tapped. The other option is to have your existing studs pinned, but that, too, calls for the heads to be removed.
Jake
Old May 30, 2005 | 07:12 PM
cplonner's Avatar
cplonner
i have a .474 int/exh lift cam in there right now, and my intake manifold is the scoggins dickey ported base manifold.
if i have a .474 lift in there right now, then i would have to set up the heads to accept a higher lift than .480 so that i can accept the 1.6 rocker arms, is this right?
i wanna pull the heads in a little while to port and polish them, so i problably will do it all then if need be.
let me know if im way off track with the rocker arms and the lift please
To simple rocker arm question
