go for lower notes while you're at it - C or lower IMHO. I went with E notes I think and it sounds a little more masculine than the A-C stock horns. It isn't europe, so avoid the high-pitched horns...
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
New horns are probably the best solution, but if your 96 horns are like my 88 horns you might try adjusting them. My horns sounded so weak when I bought the car it was pathetic. When I went to pull one out so Ii could use it as a guide to shop for new ones I noticed there was a small knurled adjusting bolt on the side. The bolt was locked tight due to corrosion so I had to use a vise grip to break the bolt free. Since I was planning on replacing the horn anyway, I figured I had nothing to lose. Turning the horn adjustmet bolt made a significant difference in the tone and especailly the loudness. After I got the left one tweaked to where I wanted it, I disconnected it and worked on the right side. Turns out the right side was not making any noise at all. Adjusting the bolt to max loudness soon solved the problem on that side as well. That was 7 years ago and it still Honks On.
I fixed mine in a similar way only I went so far as to cut the rivets off and disassemble the things. Tuning the screws didn't last long. There's contacts in there that become dirty, don't ask me how, it's sealed! I cleaned it all up inside and burnished the contacts with some 4 or 6 hundred grit, can't remember.
Then I just went to the hardware store and got some bolts and nuts to put it back together. Little black paint to hide the repair and they were good as new after some tweaking with the screw. I'm not cheap, I would buy replacements but I wanted the original horns and tones working.
On mine, I took the horns off, sprayed WD40 inside them and let them sit for a while. If you break up the corrosion inside, they will work again. On an old pair of horns that still didn't seem to want to work, I used a rubber mallet and hit them several times and they started to work.
If you are still thinking about upgrading, why not go with a set of the older style cadillac horns, it was a set of four and sounded almost like a train whistle. Really loud.
