Theft deterrent system on 1990 vert...HELP PLEASE!
Old May 31, 2005 | 06:17 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Theft deterrent system on 1990 vert...HELP PLEASE!
While installing a aftermarket radio I clipped some wires that went into the stock radio one was red with black lines, one was pink one is black. Now the car has issues starting...If I put everything back how it was sometimes it will turn over but gets no gas? If I connect the pink & redw black wire together it will start sometimes & run...I messed up somthing bigtime! When I connect the two wires (red with black & pink) the door light come on as well as the odometer in the cluster?
I decided to unplug the battery overnight & see what happens (putting everything back to how it started)? PLEASE HELP!!! What can I do to fix this issue?
Old May 31, 2005 | 06:43 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
Do you get a secuirity light during all this?
Old May 31, 2005 | 06:54 PM
rayosequis's Avatar
rayosequis
Check the FAQ in the electronics section, I think it may address some of these issues.
Old May 31, 2005 | 07:14 PM
yoslambo1@cs.com
I will check tomorrow...I have battery unplugged now.
Old Jun 1, 2005 | 03:54 AM
steve1ph2's Avatar
steve1ph2
i can tell you this,rule out the vats. the engine will not even turn over if the vats has been triggered.
Old Jun 1, 2005 | 08:36 AM
Alvin's Avatar
Alvin
St. Jude Donor '05
Not really, there is two vats systems. One that keeps it from starting and anthor in the computer that shuts it off the injectors. When the latter has a problem you'll see the cars cranking but shuttnig right back off.
Old Jun 1, 2005 | 08:46 AM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Assuming you removed a Bose unit. You didn't specify if the wires you indicate are the ones coming from the control head or the reciever box, but based on your observation that connecting the pink and red/blk wires will allow the engine to start, here's my guess:
Circuit 1935 from the reciever box is a pink wire. It is Ignition Out and connects at connector C2, terminal 8 to the Ignition In of the control head (wht wire). Circuit 1902 is Battery In (hot at all times) from the main fuse block. Connects at C1 to a red wire into the control head. You probably tried to by-pass the reciever box when you installed the new radio. Without this, the ignition input thru the reciever box is shorted.
Old Jun 1, 2005 | 09:21 AM
yoslambo1@cs.com
Do you have any suggestions on how to fix the problem? I am putting the wires back to how they were & left the battery off overnight...Will this fix the problem or did I do damage to something?
Old Jun 1, 2005 | 09:23 AM
yoslambo1@cs.com
Yes I can get it to do this...but if I connect the red & pink wire I can get it to start but sometimes i turn the key & get nothing...I have to turn the key several times then it will fire?
Old Jun 1, 2005 | 11:10 AM
Vette73's Avatar
Vette73
LS/MFT
Sorry man, I'm pretty good at following the Service Manual to fix 'em if they are stock, but modifying the electrical system is something I leave to the "experts". I'd suggest that you get your hands on the Service Manual section 8A -- the electrical suppliment. If you drop me an email I might be able to send you scanned *.jpg's of the pertainent pages.
Jac
Old Jun 1, 2005 | 11:57 AM
yoslambo1@cs.com
Jac
UPDATE!!!! I fixed it! I followed a noise that was clicking...Therer were two relays there...I removed them & took them apart...moved the insie clicker reassembled & all of a sudden the car was fixed!!! I am sooo Siked!!! Thankyou for the advice!
Old Jun 1, 2005 | 12:12 PM
chucks88's Avatar
chucks88
Glad I could help. Headin to heavenly tonight?
Old Jun 1, 2005 | 01:07 PM
yoslambo1@cs.com
Hey Chuck...Whats up! I might go if the weather is good....If I do I will bring my 90 Vert...Maybe someone will buy it there!
Old Jun 1, 2005 | 01:47 PM
chucks88's Avatar
chucks88
Yes........please bring it as I could use some parts off it.
To Theft deterrent system on 1990 vert...HELP PLEASE!
