Brake pad pros and cons
I got SS braided lines, powerslot rotors, and hawk racing pads. I put the pads and the rotors on at the same time and had HUGE gains as far as braking goes.
We got a set of those Ebay rotors on our 00 LS1 and I don't like them for much more than thier looks. They roar and howl when you come to a stop.
The Ceramic pads tend to be a bit more durable than the rotors, so you may get premature rotor wear. NAPA states this in their literature.
The HAwk HPS I have work very well, but I also put on the Baer Eradispeed rotors, so it's hard to tell which setup is superior(although the Baer over stock certainly should be better).
FYI Maybe change the fluid to? I used a squeeze bulb to empty and added new DOT 4 in.
I'm currently running EBC Greenstuff pads (Tire Rack has them) on my 87 autocross car and they work well for me. Like the Hawks, they have great cold bite which is great for autocross if you only get one run an hour!! They have two track days on them and they did work fine at Portland Int'l Raceway. These pads do not dust anywhere near the Hawks and they are about the same price. There is a "Redstuff" pad which is more of a track pad.
PFC Z-rated pads have a good rep here and there are other PFC compounds available for different uses. Try the autocrossing and road racing section and search for "brake pads".
If you are going beyond pads, do a complete fluid flush with a high quality DOT3 or DOT4 fluid. The Ford
HD Motorsports fluid works fine and is available at any Ford dealer. Castrol LMA is another good choice. Consider stainless flex brake lines from Earl's (Summit Racing has them for around $80) or Goodridge. Also install a set of Speed Bleeders so you can bleed the brake fluid by yourself. Get a set of p/n SB1010 bleeders from www.speedbleeder.com If you need rotors, the Baer Eradispeeds are good for street and autocross but if you are going to do something like 2-3 track days a season, stay away from the low-end drilled rotors that have had the holes drilled after being cast. The drilling will create weak spots and they will crack and possibly fail. I use plain everyday replacement rotors and just toss them when they show signs of deep grooving.
BTW, the PFC pads from AutoZone no longer have a lifetime warranty. AutoZone dumped that at the end of last year. They are now a 2-year warranty.
