No code 92 LT-1 Corvette
Old May 31, 2005 | 07:23 PM
lvjohn's Avatar
lvjohn
Default No code 92 LT-1 Corvette
Car idles rough and sputters when u first take off only when you use the air conditioning or it is hot outside (live in las vegas). Replaced map sensor and egr valve ( was giving code 32,not doing that anymore) even replaced the cats and pcv vavle and spark plugs. Thought some one else might have had same problem. No code flashing.
Old Jun 2, 2005 | 11:55 AM
Morley's Avatar
Morley
Does it do it when warmed up and you try to accelerate quickly? If so, look to the CTS.
Old Jun 2, 2005 | 06:20 PM
lvjohn's Avatar
lvjohn
Yes does it when it is warmed up and will try cts, thanks for the info...
To No code 92 LT-1 Corvette
