Question: Am I taking a chance running 9 year old Goodyear GS-C's as far as structural integrity goes? They have half the Tread left.They are the fronts of my 96'.
Ask yourself some questions....was the car sitting for those 9 years unmoved? Were they exposed to the elements? Is there any sign of dry rotting (scale, white film, cracks) And most importantly....Are you willing to risk your car and your life for $400 worth of tires? Go to TireRack.com and get your VISA card out.
I know that the Goodrich All Terrain tires on my truck and the tires on my trailer fell apart due to age and not wear. Had a blow out in the truck at 65mph (got the stains to prove it).
Age is not a good thing on tires. Make sure you inspect them.
I think the belts will be fine (structural integrity) but as for the rubber, make sure it is not cracked anywhere, etc, as previously mentioned.
Grip wise--these are bad news. Like ice skates. This will reduce your braking capability. It's not as safe, I would replace.
Don't feel bad - mine was riding on the ORIGINAL tires. 15 years old! No signs of cracking and plenty of tread. I once found a web sight that tells you how derive the date the Goodyears tires were manufactured, but I lost the link. Mine were sure the originals.
BTW - Goodyears has $60 rebates going till Saturday.
My 91 is still sitting on the original gatorbacks (33K/Mi). Parked in a garage most of its life, but the tires are pretty dried out. Finally made up my mind to invest in some new Toyo T1-S, and now they're out of production until the T1-Rs come out in the summer.
My GSC'S are 10 years old & have over 50% tred left. Am looking at Firestone Wide oval's. The GSC'S seem OK, but are hard as rocks. It is time for a change.
I have had very good luck with my BFG KDWS 255/45-17 front 285/40-17 rear. Got about 20k on front with about 30% left before TWIs. Rears.....2 sets in the same 20k...no explanation should be needed. They are great in the dry, good in rain, and so-so in snow. Yes, I got caught in 2.5" of snow this winter...like driving a 3500 pound saucer sled!!!!!
I just bought some race tires (Kumho Victoracers) and replaced the original GoodYears. I have been using the Goodyears for auto-X and they wouldn't grip at all. It will be interesting to see the difference this weekend. Maybe I'll be able to stay with the Miatas.
How can you let the tires on your vette last 9 years? Try the pedal on the right every now and then
Actually you said these are the front tires, which is understandable. This is why I like the 92 and earlier cars which have the same size tires all the way around. It allows you to rotate the tires front to rear which results in better wear patterns. In theory your tires won't last any longer... IE when you replace tires you will like have to buy 4 instead of 2. It takes longer to wear them out completely, but it costs more, so really it's a wash. It does help in this very situation though where you have likely replaced the rears many times and you just have really old fronts which could be dangerous.
Not much you can do about it if you have stock wheels. If you ever put different wheels on the car though, consider getting the same size all the way around. Your car will handle better and you can rotate them to keep your tires wearing better and all of them replaced on a better schedule.
Sorry, but it's tire time.
The oxygen crosslinks the rubber and it gets harder, losing its gripping capability...
Even without visible weathering, they are due for change out.
A simple test....
From a standing start, stomp on it and see how it hooks up...
Is it a tire smoking,smile generating EEEERRRRRRRRRRR
or a disappointing tire spinning zzzzzzzzzzzz
The originals on my '88 were the latter, last year before I bit the bullet.
The improvement in handling and cornering was incredible.
If you just use the car for cruising or driving to work, then have a trusted tire shop look at them and tell you if they are OK. Most likely they are fine.
If you actually want performance from the car, then get new tires. Old hard rubber is no good for grip.
Most good tire companys have a web site and tell you how to read the dot code on your tires........ Rule of thoumb if they are over 6 years old, replace them. Its a big problem on Campers... The tires have low miles on them , look new, but are dry rotted from the inside as well as outside and your putting your butt on the line..... Plenty of good tires around for decent prices, even Kumo's will serve you better then old ones.
I'm as tight as the bark on a tree when it comes to spending money needlessly but you need good tires.... If your like me and most vette guys you play from time to time at the upper end of the speedo, you want good tires.....
Tread depth isn't the issue, it is hardening of the rubber, not necessarily visible cracking..........you end up with virtually no traction, especially on wet surfaces
This is really a no brainer, if you ever plan on driving more than 35mph on dry pavement, or any speed on wet pavement, REPLACE them NOW.........
There was an item in the news this week about the age of tires, and the report said tires shouldn't be used more than six years even though they might still have plenty of tread. -- Eric
I don't know about 9 years, but 18 years seemed to be too long for mine. They still looked good but were hard as a rock. I hated to spend the money but felt I'd better for safety. Very slick on rainy days, and where I live there are a lot of rainy days. It was one of those things where I didn't realize how bad they really were till I replaced them. No more skating around corners. Felt like a completely different car. They definitely don't last forever.
I took the originals off mine they were 11 years old with 14000 miles on them didn't trust them .I replaced them with Kumho 712 a big diffence in ride and handling.I would replace them.
