BLAAACK Clutch Fluid???
Old Jun 2, 2005 | 09:44 PM
Donne Trav's Avatar
Donne Trav
Default BLAAACK Clutch Fluid???
It's been nearly 4 months since finally being satisfied with the installation
of a working SLAVE CYLINDER. Pedal felt a little "soft" yesterday, checked
cylinder out and low and behold, it was nearly EMPTY with a BLACKish
looking deposit at the bottom. WHAT'S GOING ON?! I went through this
same crap 6 months ago. Added some fluid and after pumping the
clutch for several minutes to get that "stiff and hard" pedal back, I
looked to check the level and WOW! The %#*&*#! fluid was as BLAAACK
as very dirty motor oil. CAN ANYONE EXPLAIN why the VERY BLACK FLUID?
THANKS EVERYONE.
Old Jun 2, 2005 | 10:23 PM
the blur's Avatar
the blur
something is contaminating the fluid...
I have the same issue in my F-body master cylinder. I flush the fluid, and 1 week later it's black again !!
Old Jun 2, 2005 | 10:24 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I cant explain that but it may be similar to when brake fluid gets old.You need to bleed it out until all the dirty fluid is gone.
I dont know from your post if you had done that already.
If your losing fluid you need to find the leak.
Good Luck!
Old Jun 2, 2005 | 10:57 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Good Luck!
Clear fluid good. Black fluid very, very bad! Flush till it's clean and then flush some more.
Old Jun 3, 2005 | 11:43 AM
dizwiz24's Avatar
dizwiz24
The rubber inside of the braided steel hose that connects the master and slave cylinder for the clutch is likely deteriorating.
I replced mine. This part number may have been discontinued and not many of them exist any more.
Good luck.
Old Jun 3, 2005 | 12:52 PM
rws.1's Avatar
rws.1
moisture and heat cause it to oxidize ( go black) and can also result in the additives dropping out of solution... deposits on the bottom
flush it out and replace it with Valvoline SynPower DOT 3 & DOT4
It has a higher boiling point and is ore resitant to moisture.
Mine is the color of fresh oil 1 year later....
To BLAAACK Clutch Fluid???
