Miniram and PVC
Old Jun 2, 2005 | 10:54 PM
91superram's Avatar
91superram
Default Miniram and PCV
Where dose the pcv connect to on a miniram
Old Jun 2, 2005 | 10:58 PM
8388's Avatar
8388
St. Jude Donor '14
Hope we're talking pcv instead of pvc you have 2 vacuum ports on the driver side of the intake. Choose one.
Old Jun 2, 2005 | 11:15 PM
91superram's Avatar
91superram
Ive seen it connected to the throttle body just bellow the valve cover breather is this the same as a vacuum
Old Jun 2, 2005 | 11:50 PM
8388's Avatar
8388
St. Jude Donor '14
Anywhere behind the throttle body on the intake will pull vacuum. The size of the port is whats important. For the PCV you'll need to hook into one of the larger ports on the intake as well as the brake booster. The smaller ports can be used for map sensors, fuel regulators, etc. You can always use T and Y adapters if needed.
To Miniram and PVC
