Removing single head bolt...
Old Jun 3, 2005 | 08:07 AM
ztrips's Avatar
ztrips
Default Removing single head bolt...
I have coolant leaking out one head bolt. This is a new engine build. I either forgot, or put too little thread sealant on that bolt before I put it in. It's one of the "short" bolts below #4 spark plug. Would there be any harm in pulling the single bolt, sealing it, and torqueing it back down?? Or do I need to loosen and re torque all of them???
Thanks!
Old Jun 3, 2005 | 08:17 AM
rick lambert's Avatar
rick lambert
Just pull the one and don't worry about it, I've done it and had no problems.
Old Jun 3, 2005 | 12:04 PM
Corvette0096's Avatar
Corvette0096
Yah you will be fine... Alot better off then where you are now.
To Removing single head bolt...
