Weather stripping again
Old Jun 3, 2005 | 04:06 PM
90SteelBlueCoupe's Avatar
90SteelBlueCoupe
Default Weather stripping again
I've just got my car back from the body shop... He set the door without the weather stripping in place ... the door shuts perfect .... I test fitted the new weatherstripping and the door would not shut properly... it would catch the first click but would be real hard on the second final shut... Anyones experience ??? Wondering if I should trim some of it..??
Old Jun 3, 2005 | 04:18 PM
bogus's Avatar
bogus
NO!!!!!!!!!!!!!!!!!!!!!! don't trim.
new WS will be a tighter fit. you may need to adjust the glass a little to fit best.
Old Jun 3, 2005 | 04:22 PM
1stC3Vette's Avatar
1stC3Vette
i have noticed that the weatherstripping at the front of the door (hinge area) is where the problem is. Try to move it a bit and see what happens.
Did you use OEM originals or someone elses? Either way, do not trim it.
Good luck,
Dino
Old Jun 3, 2005 | 04:40 PM
90SteelBlueCoupe
Good luck,
Dino
Bought them from ZIP .... The test fit looked good... on the door everything fits perfect... even the screw holes...
your're right about the front of the door ... It's real tight...
To Weather stripping again
