95 Injector Resistance
Old Jun 3, 2005 | 09:06 PM
BMarsh93's Avatar
BMarsh93
Default 95 Injector Resistance
Just checked resistance on my fuel injectors in my 95. Engine was hot and all ranged from 13.2 to 13.4. The range seems pretty close but are they suppose to be 15 - 16 ohms? Or am I confusing this with the L98 injectors?
Old Jun 4, 2005 | 12:04 AM
Morley's Avatar
Morley
Well ,as long as all 8 of them were in that range, I'd call it good. Even if they are supposed to be 15-16 ohms, your meter could be off a little in the lower ranges. Most meters have a 1-2% error tolerance also.
Old Jun 5, 2005 | 03:01 AM
Mo_Bandy's Avatar
Mo_Bandy
If you are in the 14-16 ohm range you'll be fine... They are supposed to be around 16, but my 36 pounds are 14 and the car runs fine...
Mo
To 95 Injector Resistance
