Belt Slip/Squeal !!
Old Jun 3, 2005 | 10:58 PM
Herb's Avatar
Herb
Default Belt Slip/Squeal !!
I just took off my ATI blower for an oil change and now it squeals with the air conditioner on. It didn't before.
With the A/C off I don't hear the squeal but I'm only getting about 5 lbs of boost where before I was getting about 7 lbs.
I moved the adjustment pulley back and forth thinking maybe it didn't release all the way but I still have the squeal.
Any place else I can adjust? Any ideas?
Herb
Old Jun 5, 2005 | 02:48 AM
Mo_Bandy's Avatar
Mo_Bandy
There may some oil on the belt?
You could try some belt dressing... or you may need to go with a new belt... aside from the tensioner, there is not much else...
Mo
Old Jun 5, 2005 | 01:36 PM
Herb's Avatar
Herb
Thanks Mo. It worked!
I always thought that stuff was bogus.
Old Jun 5, 2005 | 03:21 PM
lead foot 85 vet's Avatar
lead foot 85 vet
changing the belt several times a year seems to work for me, they harden up pretty fast with the engine heat.
Old Jun 5, 2005 | 06:32 PM
Mo_Bandy's Avatar
Mo_Bandy
You're welcome,
There is enough tension on the belt that it seems to work better on a S/C than an alternator belt...
Mo
Old Jun 13, 2005 | 01:26 PM
apeacefulstorm's Avatar
apeacefulstorm
Default sort of related
How often do you have belt problems with the supercharger?
Old Jun 14, 2005 | 10:11 PM
Mo_Bandy's Avatar
Mo_Bandy
My gatorback belt has lasted about 2 years now... also a lot depends on your S/C pulley size as well , obviously the smaller the more tendecy to slip... I'm running a 3.125
Mo
To Belt Slip/Squeal !!
