'92 with intermittent ABS ASR problem
Old Jun 6, 2005 | 08:22 PM
Ivory90's Avatar
Ivory90
Default '92 with intermittent ABS ASR problem
My coworker has a '92 LT1 with 40K on the odometer. This car started having problems with the braking system 2 wks ago. On startup it doesn't do the system selfcheck. When this happens the ABS and ASR lights come on. The problem so far is intermittent, if the ABS self check happens then the ABS ASR lights don't come on. He also mentioned that the car has not had the braking system bled ever and he's got the factory brakes/rotor/calipers on. The ABS ASR and master cyclinder are all original as well.
He also stated that his think that there's some caliper drag happening that preceeded the self check problem and in ongoing.
Any ideas about his problem and resolution?
Thanks,
Frank.
Old Jun 6, 2005 | 08:26 PM
bogus's Avatar
bogus
my first suggestion would be to do a complete brake overhall.
A dragging caliper might cause this, but I suspect it's a wheel speed sensor.
Without scanning for codes (which is easily done), I am stabbing in the dark here...
Old Jun 6, 2005 | 08:48 PM
Ivory90's Avatar
Ivory90
on the '92 does the ALDL look like the one on the '90? What pins should be jumped to get codes for ABS and ASR?
Old Jun 7, 2005 | 04:32 AM
Casethecorvetteman's Avatar
Casethecorvetteman
my 87 did that a while back, deffinatly change the fluid, that should have been done ages ago, it absorbs water and swells the seals. Look at all the related ABS relays too.
Old Jun 7, 2005 | 11:54 AM
bogus's Avatar
bogus
I will email you something.
Old Jun 7, 2005 | 12:09 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
On a 92 its pin A shorted to pin G
Or if your looking at the connector , top right shorted to bottem left.
F|E|D|C|B|A
G|-|J|K|L|M
Old Jun 7, 2005 | 12:19 PM
Leavundst's Avatar
Leavundst
Also just make sure you have enough fluid. Mine was just a tiny bit low and I would occasionally get ABS and sometimes ABS/ASR lights.
Old Jun 7, 2005 | 04:42 PM
Ivory90's Avatar
Ivory90
Thank you Gentlemen for you help. I passed this thread along to my buddy. He's going to change the fluid and chk the codes. I've given my recommendations on what he should do and we'll see what happens.
Thank again!
Old Jun 15, 2005 | 08:04 PM
Ivory90's Avatar
Ivory90
Default Followup by coworker (Su)...
Frank, just got a few minutes last night, so I tried..
Module/Segment 9.1 showing error code as "H83" Low brake fluid.
Sure enough, look under and found the leek.
Thanks,
Su
Thanks again! Su's pretty cool, he's got a very low miles 14K or so '92 LT1 which has never scene rain and has only been washed 10 or so times. It's a real garage queen and has a remenant smell of new car. He sprung his first leak, the brake fluid reservoir is his problem.
Thanks again to all those that chimed in with opinions/advice.
Frank.
Old Jun 15, 2005 | 08:06 PM
Ivory90's Avatar
Ivory90
Thanks,
Su
Thanks again! Su's pretty cool, he's got a very low miles 14K (earlier I thought he said 40K but it's got 14K) or so '92 LT1 which has never scene rain and has only been washed 10 or so times. It's a real garage queen and has a remenant smell of new car. He sprung his first leak, the brake fluid reservoir is his problem.
Frank.
To '92 with intermittent ABS ASR problem
