Chip Changes during Dyno Tuning
Old Jun 15, 2005 | 04:43 AM
ZR1forFun's Avatar
ZR1forFun
Originally Posted by DOCTOR J
A narrative recently prepared for a fellow new to tuning is located here
(with even more references):
http://forums.corvetteforum.com/show....php?t=1069644
I'd modestly suggest reviewing the parts about 'getting the low-speed
fuel tables in good working order FIRST, before doing the WOT tables'.
In my experience, it's generally true that if the foundations are correct,
the high-speed fuel will sort itself out with little further anguish.
The reasons for this are several, but I'll burden you with only one now:
In most GM programs, PE and AE are ADDERS to the base fuel term.
(The equation for fuel load was given in a previous reference.)
That is, in the PE vs. CT and PE vs. PRM tables, GM typically adds ~ 25%
EXCESS fuel to the BASE engine load (or some number like that). Thus
if the base fuel calculation is reasonably correct (VE tables) - there is
scant danger of the engine running lean. Hence there will be less need
to fret over where the 'BLMs are locking' - since the BLMs will already
be ipso facto in the proper range.
Good luck with your project.
DrJ, and others, thanks for your valued advice and patience, it's nice to be able to come here and discuss my experiences as I struggle up the learning curve of EFI tuning.
