Grinding sound from the ZF... HELP!
Old Jun 29, 2005 | 06:32 AM
johnzz4's Avatar
johnzz4
Originally Posted by LT4CompYell
Let me understand what you're saying: you converted to a sm steel Centerforce flywheel and dual clutch assembly. It's noisier than the stock unit, all new, would've been. But it's not as loud as the sm aluminum flywheel setup would've been. And it's putting down the power, albeit with lots of noise at various rpm's and in neutral. Is that about right?
Yes, that's correct, although I don't know how loud an aluminum FW is... never tried it. Other than that, you are dead on...
Old Jun 29, 2005 | 06:33 AM
johnzz4's Avatar
johnzz4
Originally Posted by bogus
did your guy match balance the new flywheel to the original dual mass?
No Bogus, I am the one that posted another thread about this since I don't have access to the original FW. I am balancing this this weekend. I hope this will help!
Old Jun 29, 2005 | 06:48 AM
aqualung's Avatar
aqualung
I was just checking out Carolina Clutch and they do offer LT1 performance kits which replace the DM with an aluminum SM flywheel.
Has anyone tried these packages?
Do these packages make the awful noise Bogus is describing?
