I am planning on adding a supercharger to my L98 after I graduate (should be at the end of the summer ) I am planning on adding helpful bolt ons untill then and wanted to know if there are any to avoid. I am adding a Super Ram that I already bought in the next few weeks b/c of a blown intake gasket.
avoid an underdrive pulley for sure, Other than that I would say stay away from getting a new set of injectors and a cam until you know what you're going to do with the blower. Everything else would be useable with a blower, especially those exhaust mods.
I agree, but the cam can be swapped to a blower grind. Most blower grinds are very similiar to EFI grinds. My blower cam has the same part number and specs as an EFI cam, right there in the comp catalog.
The biggy to avoid is an aftermarket chip (hypertech and the like). The usually add a little timing, which is the opposite of what a blown car likes- and could end up damaging your engine. My ATI instructions specifically said to put the stock chip back if its been replaced.
if it's only 3 months I would say hold off on everything and just do it all at once. Sure slap on the easy bolt ons, intake, rocker arms, throttlebody. I would stay away from anything that takes a computer reprogram or more than an hour to do.
You'll want to save that money for the blower kit as well. You're gonna spend more than you think, chances are alot more if you want it to run right.
well i plan on buying parts from here over the next few months to save some cash. All I have now is the intake. But I am going to order A FPR and hopefully injectors and a 58 mm TB.
are you going to be running an FMU with the blower? How much boost? These are things that will determine what size injectors you get. You probably won't need a 58mm TB, but I dont' think it would hurt you at all either.
i have been talking to Greg at Blowerworks and going through his info and think somewhere in the stage 2 area. I would like 400 RWHP and by his numbers this should not be unimaginable with the stock bottom end.
Thanks Guys
You need to look at some items to decide what to go with and how much response ability you want to accept to have a well running car. What does the kit you are going to purchase come with MSD, fuel pump, injectors? If you make changes to a car a kit manufacturer has not addressed in advance, do you have items needed to burn chips and data log? A wide band O2 is something to think about? Adding a supercharger to a stock car is easy, most, if not all the issues are addressed for you. Adding a new intake, headers, rockers, and/or cam change your fueling and timing requirements and need to be addressed with the s/c kit manufacturer in advance to run well. Some manufacturers have stages, 1,2,3, etc. If you don't plan ahead with the kit manufacturer be prepared to program it yourself, change ecu and/or pay for dyno tuning which gets expensive.
I suggest you beg steal or borrow the money and buy Aaron's kit( AKRacing). He can tell you everything you need to know about L98 kits as he been there, done that several times over.
Are the L98s easier or harder to tune then the LT and LS cars?
Tuning a $32, $6e and $8d are not that difficult. They just take a little time an effort to understand whats going on. I cannot address the lt or ls cars.
Regarding your injector question. You can purchase new 24#ers around the same price and 30#ers for another $30.00 more. Check out ebay.
You are running 42lbers? wow that seems like a lot, with just 10 lbs will 24s work for me or should I look for higher?
It contains all the formuals and worksheets to help you decide what injectors you will need. Ford injectors are rated at 37.5 psi. The L98 fuel pressure with the factory regulator have 43-45psi. If you are going to use an fmu it can raise fuel pressure up to 90 psi. Do the math and see what you need and decide how you want to control your fueling. I originally ran 24#ers with an FMU for 3 years before I blew my intake gasket and made a few changes to my stock engine. To run injectors larger than 24 psi you need the ability to program your own car.
