A/C Problems
Old Jun 8, 2005 | 09:00 AM
RED LT4's Avatar
RED LT4
Default A/C Problems
Why would the A/C clutch continue to cycle on and off? The clutch engauges for about 5 seconds and then cycles off for about 10 seconds and then back on for 5 seconds
Old Jun 8, 2005 | 09:14 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
Low on freon.
Old Jun 8, 2005 | 10:36 AM
RED LT4's Avatar
RED LT4
That sounds simple. Any idea on what type freon in a 96?
Old Jun 8, 2005 | 02:19 PM
DRAKEFAMILY2
I believe r134a, look on the compressor should a label, or one somewhere around a/c stuff. I think they went from r12 around 1992 or 1993. Also could ask the dude at the auto parts store that sells freon.
Old Jun 8, 2005 | 02:30 PM
dchildress's Avatar
dchildress
1994 was the first year for R134a. A 12oz can sells for about $6. When buying the R134a I recommend buying a can that has sealer and tracer dye in it. This will help seal the system and help find the leak if it has one. Spend the money and get a hose kit that has the guage built in. This will help make sure you do not over or under fill your system. The port is on the passenger side next to the surge tank for the radiator.
To A/C Problems
