SR Intake Gasket????
Old Jun 9, 2005 | 12:30 AM
Dougs 90's Avatar
Dougs 90
Default SR Intake Gasket????
What is the intake gasket (FEL-PRO) for the Accel SR Intake manifold?
Old Jun 9, 2005 | 03:14 AM
conv90's Avatar
conv90
I'm using 1205 and it seems to seal good.
Others will say 1204 are better.
For my application with trickFlow heads the 1205 are a must.
Old Jun 9, 2005 | 04:57 AM
USAsOnlyWay's Avatar
USAsOnlyWay
The SR base is actually right between at 1204 and a 1205...
...I think...
Old Jun 9, 2005 | 06:08 AM
rrubel's Avatar
rrubel
When I was trying to fit gaskets, I could NOT get one that fit perfectly (too big or too small). I went with the 1205 and a mild port job (which was another story unto itself).
You could always get the 1204 and trim it.
[RICHR]
Old Jun 9, 2005 | 06:53 AM
USAsOnlyWay
My SR base is also ported to a 1205.
Old Jun 9, 2005 | 07:36 AM
Red Tornado's Avatar
Red Tornado
Doug, my heads are 190cc (actually 187cc), and my SR manifold was lightly ported to match a 183cc LPE port job.....the 1204's were the perfect match in my case.
Old Jun 9, 2005 | 10:15 AM
SDS Photography's Avatar
SDS Photography
so stock we should use a 1204?
where is the best place to get one?
Old Jun 9, 2005 | 10:24 AM
scorp508's Avatar
scorp508
I buy em' from Summit.
Old Jun 9, 2005 | 09:22 PM
rrubel's Avatar
rrubel
I get mine from Competition Products for about $14. Mr. Gasket also has a clone set that's maybe $10 at Auto Zone. Mr. Gasket owns Accel, so you'd expect those would also work.
[RICHR]
Old Jun 10, 2005 | 09:18 AM
Dougs 90's Avatar
Dougs 90
CHIT! No help at all, I was trying to figure out whether to go with AFR 180's or AFR 195's and the fella told me if my intake needs a 1204 gasket, get the AFR 180 and if it uses a 1205 get the AFR 195 heads......guess I need to toss a coin eh? Even better, maybe I will run a poll for which heads I will get. Thanks though now I know the deal!
hey Brad, did you check the paint card out I posted the other day?
Thanks everyone,
Doug
To SR Intake Gasket????
