spare tire restraining bolt
Old Jun 9, 2005 | 03:52 PM
jschoof's Avatar
jschoof
Default spare tire restraining bolt
I am replacing the bolt assembly that holds the spare tire pan in place - the one that slides in the the bracket mounted behind the license plate. A friend of mine torqued on it last weekend and farked the whole thing up.
Anyway, should i put some sort of anti sieze compound on the threads when I assemble this thing? if so what kind do you recommend?
Old Jun 9, 2005 | 05:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Any good antisieze will be fine and is a good idea on most anything under the car since it's subject to weather, road conditions, etc. I like Permatex antisieze lubricant. This is a good all purpose product to keep around. It's also an excellent product to use on the threads of pullers to protect them from the high loads they're subject to and keep them in good shape. Works great for high heat applications like exhaust hardware too and really anywhere that antisieze is called for on a car.
Old Jun 9, 2005 | 05:40 PM
Slalom4me's Avatar
Slalom4me
of anti-seize compound on the threads when I
After removing the bolt entirely and cleaning
the threads with a wire brush, I used wheel
bearing grease to protect my bolt. I ran a
bottle brush (from an oil galley cleaning kit)
up inside the 'nut' before reassembly.
Note that parts for this are no longer serviced
individually. GM still offers a kit consisting
of the bolt, the formed T-washer and the
long tubular receiving 'nut'. P/N# 10089668,
there was stock in Boston this week, about $45.00.
Regards,
Ken R.
Old Jun 10, 2005 | 02:59 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You could probably 'buy' one for free on the forum. Half of us have tossed the spare and have those bolts just laying around in our parts bin.
Old Jun 10, 2005 | 09:05 AM
jschoof's Avatar
jschoof
was $40 from corvette central >
Old Jun 10, 2005 | 03:37 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I wouldn't use anti-seize either.
The issue on this bolt isn't seizing, it's corrosion. Use a good anti-corrosion compound like LPS3.
Besides, put anti-seize on it and the first time you have to change a tire, you'll have anti-seize all over yourself and you know how tenacious that stuff is....
Larry
code5coupe
Old Jun 10, 2005 | 05:00 PM
Corvette Kid
Larry
code5coupe
Last time I checked, antisieze prevented corrosion too, but you're right, it's some messy stuff. Tell me more about LPS3.
Old Jun 10, 2005 | 05:11 PM
jodyeastman's Avatar
jodyeastman
I had our machine shop make a SS bolt with some extra thread. I have not installed it yet but it should allow me to push the tire more snug to the underside. Hopefully after this, you won't see the tire from the rear.
Old Jun 10, 2005 | 05:20 PM
Corvette Kid
Let us know how that works out. I'd probably carry my spare more often if that was the case. But as it is, I prefer to look at my nice, clean rear end components when I approach my car from the rear! I never realized how fugly that stuff is until I took it out!
To spare tire restraining bolt
