Key-in chime problem
Old Jun 9, 2005 | 05:40 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Key-in chime problem
When I put my key in, sometimes I get a chime and sometimes not.
If I spray contact cleaner in the key slot to clean the contacts, will it hur my ignition?
Old Jun 9, 2005 | 06:16 PM
dchildress's Avatar
dchildress
I don't think that is your problem. My chime only works when the car is cold. I have been told it is the relay for the chime. My headlight chime is the same way.
I would avoid spraying contact cleaner in the ignition, there is a remote chance it may damage the VATS.
Old Jun 9, 2005 | 06:48 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Thanks!!
Old Jun 10, 2005 | 01:44 AM
BlackbirdZ07's Avatar
BlackbirdZ07
The problem is probably either the relay or the chime itself. Mine doesn't work sometimes. Bang on the top of the dash in the center with your hand; sometimes that fixes it for a little while.
Old Jun 10, 2005 | 09:01 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
i think you have a bad ding... ding... dinger
Old Jun 10, 2005 | 11:39 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
We are not amused!!
Old Jun 10, 2005 | 11:56 AM
Aardwolf's Avatar
Aardwolf
Mine does that to! I reeeeally like it! To bad it's not a factory option. In my old car I disconnected that damn bonger. In certain situations I enjoy listening to the radio with the door open and can't stand hearing "BONG BONG BONG" relentlessly!
With mine I push the key in and jiggle it just a little, the bonger quits. I've worried a few times about it being a symptom of something more serious to come. Two years and no change yet!
Why would electrical cleaner damage the VATS?
Old Jun 10, 2005 | 12:02 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
It is not that I like the chimes, I am with you that it can be annoying.
But, one of my many problems is I cannot program my PKE. And I have a new receiver and transmitter, but I have heard that if the PKE does not know that the key is in the ignition you cannot program the receiver.
I do not know why you cannot put contact cleaner either!!
Old Jun 10, 2005 | 01:01 PM
OdinsRage's Avatar
OdinsRage
GM quality woes... happened on ALL my gm cars, 92 cadillac, 01 camaro SS, and now my 96 CE. I like to be able to tug the key out in the ACC position so i can listen to the radio w door open like someone previously said.
Old Jun 10, 2005 | 01:08 PM
IBEAM700's Avatar
IBEAM700
Originally Posted by Randy93
We are not amused!!
Come on, where’s your sense of humor
Old Jun 10, 2005 | 02:00 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
My 90 only chimes when key is put in with door open then stops when door is closed. It's so you dont lock the keys in. Are you sure this is not what your experiencing, sometimes door open,sometimes closed?
Old Jun 10, 2005 | 02:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I just replaced the ign switch in my '88 and found a little reed switch which the key closes when inserted fully. When the system detects closure and the driver door is open the chime is activated.
The reed switch could be dirty, causing the intermittent problem or perhaps the lock has loosened so that the key sometimes closes the reed switch.
But spraying contact cleaner into the key opening isn't likely to get any of the cleaner fluid to the reed switch. That swtich is a PITA to access even with my tilt/tele wheel and I suspect it's more so with an air bag setup.
Old Jun 10, 2005 | 02:19 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I am sure, a month ago I was working on my car with the keys in the ignition and all of a sudden the key reminder started sounding. I was putting in coolant at the time, so I know it wasn't what I was doing.
Old Dec 31, 2009 | 12:33 PM
m.kempel's Avatar
m.kempel
4th Gear
Default lights too
Hi,
I have a '94 C4 with a similar problem with the chimes. When i leave my lights on and open the door, the chimes only work with the car very cold, like in winter.
Could it be with the door switch?
I have heard this suggested for other cars and similar problem.
Thanks for the help!
Mike
Old Dec 31, 2009 | 02:00 PM
techvette's Avatar
techvette
The dinger is somewhere in the dash...I have been told you need to find it and clean the connections.
Old Dec 31, 2009 | 08:46 PM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
Hi
My 91 used to have chimer problems too. I traced it to cold-solder joints on the chimer box itself (I would slight flex the connector in my hand and the chimer would start chiming).
I repaired it by resoldering the joints at the pcb. Hardest part is getting to it (top of dash has to come off.)
john
Old Dec 31, 2009 | 10:01 PM
mike100's Avatar
mike100
If you take the steering column apart to the step where the turnsignal assy is removed, there is a key-in ign contact you could take out.
my dinger is also sick...sounds terrible
Old Jan 1, 2010 | 03:36 AM
pologreen1's Avatar
pologreen1
KNOCK IT OFF !
Old Jan 1, 2010 | 07:16 PM
grinditout's Avatar
grinditout
I have one for sale. pm me if interested.
To Key-in chime problem
