Shocks?
Old Jun 12, 2005 | 10:03 PM
DG'sVette's Avatar
DG'sVette
Default Shocks?
I'm a new Vette owner. I have a 95 coupe. Bought it in January. Drove about 4000 miles so far, the car has 70000 on it now. The car seems to want to bounce alot when going over bumps. Is this normal or am I in need of new shocks? If its the shocks, should I go with the stock Bilstins or something else?
1995
Z51
G92
Old Jun 12, 2005 | 10:30 PM
95polo's Avatar
95polo
I have a 95 with about the same miles as yours. I just put the stock Bilsteins back in it.
Old Jun 12, 2005 | 10:44 PM
vader86's Avatar
vader86
At 75K they are worn, so yours are just about gone.
I would replace with Bilsteins.
Old Jun 12, 2005 | 10:51 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
No FX3?
Old Jun 12, 2005 | 10:59 PM
DG'sVette's Avatar
DG'sVette
Originally Posted by Jeffvette
No FX3?
Too much for me!
Old Jun 12, 2005 | 11:09 PM
Jeffvette's Avatar
Jeffvette
Is that a option currently on the car is what I was asking. Normally Z51 and FX3 went together.
Old Jun 12, 2005 | 11:13 PM
DG'sVette's Avatar
DG'sVette
Its not on mine. I'm new so... I'm just going by the RPO codes I found on the car.
Do you have the FX3? If so would it be worth the money to upgrade?
Old Jun 12, 2005 | 11:17 PM
Jeffvette's Avatar
Jeffvette
If you don't have it, don't worry about it. Kittmaster added it to his car, but it ain't cheap and the additional wiring is a headache.
Since you have the Z51 shocks, if you are happy with a performance minded ride, find a set of bilsteins for the Z51 car. Several shops sell them.
Bilstein Shocks
Old Jun 13, 2005 | 01:12 AM
Slalom4me's Avatar
Slalom4me
You can also get Bilsteins that are valved for autocross
work, if that's your cuppa joe now or in the future.
Alternatively, you can return your existing Bilsteins
and have them rebuilt: stock valving or for AutoX.
Check the Bilstein site for details and $$$. When I
last looked, there wasn't THAT much difference
between replacement and rebuilding. I haven't
made the move either way yet.
Old Jun 13, 2005 | 07:13 AM
jwt1603's Avatar
jwt1603
On the stock Z51 shocks it's almost the same price to have them rebuilt. For the hassle of taking them off, putting cheap shocks on / or not using the car, waiting for them to come back, you're almost a wash between buying new and rebuilding. If you had the FX3 you're better off getting them rebuilt since it's about half the price of new and new FX3 shocks are close to $200.00 each.
Old Jun 13, 2005 | 09:45 PM
DG'sVette's Avatar
DG'sVette
KYB Shocks?? Are these any good? Set of 4 = $140 Rock Auto
Bilstein Z51 Package = $280 Corvette Forum
Old Jun 13, 2005 | 09:53 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
My `87 has 36,000mi. on it with the Z52 suspension. The Bilstiens made the car ride like a stage coach. I replaced them with Gabriels from Autozone for $20.00ea., & the car rides & handles great.
Old Jun 13, 2005 | 10:03 PM
jwt1603's Avatar
jwt1603
Depends on what you are looking for. Do you want a semi-smooth, fairly comfortable, daily driver or something that's a little more aggressive? You can have more fun with the Z51 cutting up freeway on ramps or club autocrossing but you give up ride comfort. Still won't be as hard as FX3 with Z07 though.
Old Jun 13, 2005 | 10:13 PM
Dartvader's Avatar
Dartvader
Edelbrock IAS shocks are a nice compromise between rally shocks and cruising shocks. They have an inertial valve that changes with the suddeness and severity of the bump. I have liked them very much on my old Darts, which have essentially the same type of front suspension as my Vette. One of my Darts I have installed tubular upper control arms, hard bushings, and heavy duty torsion bars, and it rode like hell until I put on the Edelbrock IAS shocks. The Edelbrock shocks made it corner flatter, and ride smoother. It seemed like magic to me. I have not put these on my Vette yet, which is a '95 with 72K miles on it, but I plan to. By the way, when I installed the RD Cross Fame on my Vette, much of the bounce that I thought was shock related went away.
Old Jun 13, 2005 | 10:48 PM
DG'sVette's Avatar
DG'sVette
What is this & what does it do?
Old Jun 14, 2005 | 07:55 AM
Slalom4me's Avatar
Slalom4me
What is [a cross-frame brace] & what does it do?
It is an 'X' shaped aftermarket brace that mounts
under the car at the four corners of the frame
section between the front/rear suspension areas
for the purpose of reducing torsional twist. If a
chassis does not have sufficient resistance to
torsional loads to cope with stiff spring/anti-roll bar
rates, then bump and cornering loads twist the
chassis instead of compressing the suspension.
Anything that is effective at making the chassis
into a rigid platform assists the suspension to
perform as designed and improves ride/handling.
(Deactivating 'Generalizations' now.)
A forum search (advanced, including archives)
will serve up a wealth of questions, opinions and
testimonials. This link to RD-Racing will provide
product info.
So as not to hijack this thread, create a new
post with 'Cross-Frame' in the subject heading
to ask further questions.
Old Jun 14, 2005 | 10:49 AM
olefam's Avatar
olefam
I had the stock "soft ride" suspension with Bilsteins on my '91. I decided to replace with KYB's and they have been a good choice for me. A little firmer, but not harsh. All of my driving is either city or highway - I don't auto cross. Just my .02 worth.
Glen
Old Jun 15, 2005 | 12:38 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I have a 95 coupe. the car has 70000 on it now. The car seems to want to bounce alot when going over bumps. Is this normal or am I in need of new shocks? If its the shocks, should I go with the stock Bilstins or something else?
It's time to replace your shocks. 70K miles on the original shocks (even if they ARE Bilstein) is a lot.
I think Bilstein's are the best bang for the buck; far superior to Gabriel's and KYB's for about $70each. How can you go wrong?
...and yes, it's only a few dollars more to buy them new than to have them rebuilt. If you have to ship them to Bilstein, then it's about a wash.
Larry
code5coupe
To Shocks?
