Hard Brake Line Ends
appropriately sized flare nut wrench (link).
These wrenches look like double box-end wrenches
with one side cut open.
required? Looks like a double flare tool from the
manual. Is it cheaper to get new hard lines and if so
where do you get them?
the existing fitting off with a mini tubing cutter, recover
or replace the existing fitting and reflare the tubing.
I am not familiar with the '92 and do not know
whether conventional double-flares are used or not.
The catch is whether there is enough tubing to make
a cut and still reach the brackets. If not, then it is
necessary to locate lengths of fabricated, DOT
approved brake tubing, bend them into shape and
replace the existing ones. Parts places like NAPA
are one source for these pre-fabbed hard lines.
Alternatively, one can buy DOT brake line tubing
& fittings to fabricate his own lines.
Do not skimp on the tubing. Do not fudge with
the fabrication. Lives, property, wealth and
emotional well-being are at stake. Get help
with the work or have it done at a reliable shop
if you do not have the experience and knowledge
to do this yourself.
After the damage is done, it may be possible to cut
