383 cam suggestions
Old Jun 14, 2005 | 01:03 AM
Insane1's Avatar
Insane1
Default 383 cam suggestions
I thought I had my cam figured out. While taking the 383 out of the Camaro that is going into my Vette I found it had the saddles cast into the block for the factory roller rocker retainers. I am planning on drilling and tapping the saddles and put in the roller cam and lifters from my '87 Vette motor. My question is which cam should I put in?
My specs are -
Cast iron block and heads
Heads ported and polished with 2.02" valves, screw in studs and guideplates
1.6 Crane roller rockers
stock exhaust
19# Ford/Bosch fuel injectors
Very little work done on the intake
Gutted MAF
Cut lid
MUST PASS CALIFORNIA SMOG
Of course it would have to idle and have sufficient vacuum
I would like the power band to be in the lower rpm range.
I was looking at a one of these cams
Int Exh
264 274 - Duration (gross)
216 224 - 050" duration
440 480 - Valve lift 1.5 rockers
469 512 - Valve lift 1.6 rockers
112 Lobe center
or
Int Exh
270 282 - Gross duration
214 227 - 050 duration
480 515 - Valve lift 1.5 rockers
512 549 - Valve lift 1.6 rockers
112 Lobe center
or
Comp Cams 12-707-8
244 050 Duration
586 lift
110 Lobe center
or
suggestions?
Remember, I need to keep this California Smog Emmisions legal.
Will I need to change the injectors?
Any help/suggestions would be greatly appreciated.
Does anyone know what the specs are for a stock roller cam out of an 1987 Vette?
Old Jun 14, 2005 | 02:18 AM
SHINOBI-X's Avatar
SHINOBI-X
202/206@.050
.403in./.415ex. lift with 1.5's
115LSA
i believe those are them. if it need correcting someone please chime in and correct.
im very interested to see what people on the forum have to say about a cali smog legal 383.
i was looking at a crower flat tappet grind with
214/222@.050
.455in./.470ex. 1.5
114LSA
i forgot duration....
not big but for smog and a torque monster for the street and strip it should do well for a mild stroker that runs clean and idles smooth.
Old Jun 14, 2005 | 03:13 AM
Morley's Avatar
Morley
I'd rethink those injectors. 19# seems awfully small for a 383, I'd, at the very least, step up to the stock size 22# or some of the SLP 25# for $99.
Old Jun 14, 2005 | 05:22 AM
conv90's Avatar
conv90
...yes you really need a bigger size injector to feed the engine..
-beppe-
Old Jun 14, 2005 | 10:38 PM
Insane1's Avatar
Insane1
I kinda figured the injectors were too small but since my other ones weren't working and these were free.........
What I really want to know is about the cam. Anyone?
Old Jun 14, 2005 | 11:45 PM
mikeltm's Avatar
mikeltm
The best cam grind for a 383 that I have found is 234/242 with a lift 0f 539/558 112 sep using 1.5 rockers this is a custom roller grind and if your heads will flow you can make serious HP and torque #s still pull 11+ lbs of vaccum and maybe pass emmisions with the right tune
To 383 cam suggestions
