antenna motor dead ?
Old Jun 14, 2005 | 11:19 AM
stanandsue's Avatar
stanandsue
Default antenna motor dead ?
I have searched the antenna threads. The power antenna on my 92 convertible stopped working last week - half-way up. I had routinely cleaned it, and I was able to manually move it up and down. I hear the relay click under the dash as normal, but the motor is making no noise.
I checked the fuses of course, and reached-up under the fender to see if a wire was loose but could not find a problem.
Do the motors on these die often, and are they difficult to replace? I found some threads on motor replacement. Anyone do this job on a 92 convertible? Thanks.
Old Jun 14, 2005 | 12:22 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
More than likely you've got a jammed section of nylon antenna mast inside the motor that's fouling it up. Check your fuse to make sure it's not blown.
I removed the motor on my '92 Coupe (chances are you saw the TechTip I wrote in the C4 section. You should be able to use those instructions to get your motor out, open it up, remove the offending bits of broken ribbon, then install a new mast from your local Chevy dealer.
Old Jun 14, 2005 | 12:34 PM
stanandsue's Avatar
stanandsue
thanks for the tip - I'll give it a try
Old Jun 14, 2005 | 01:52 PM
ittlfly's Avatar
ittlfly
Same problem on my 92 a few months back. Not a hard job, just time consuming.
Old Jun 14, 2005 | 01:58 PM
93Ruby's Avatar
93Ruby
If you find that the motor is dead or don't feel like taking apart the old one, look on ebay. I just replaced mine with a factory new one for about $93 with shipping. Good Luck!
Old Jun 15, 2005 | 05:05 PM
stanandsue's Avatar
stanandsue
thanks - I'll probably wait for cooler weather to do this job, but I appreciate the responses
To antenna motor dead ?
