I need a relay that does this:
Terminal 1 = Hooked up to a Keyed Power Source
Terminal 2 = Hooked up to Constant 12v+
Terminal 3 = Hooked up to Accesory
What I want it to do, is allow power to the accesory, only when the key is turned on. I just need to know the # for this relay so I can pick it up. Thanks
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
SPST relay. Radioshack or autoparts store.
SPST, SPDT, DPDT, and so on, is used to describe relays and switches. Basically the same. Relay uses a electromagnetic coil to 'throw' it , and the switch uses your finger. Hey, you asked.
Why not try a latching relay for the accessory circuit with your keyless channels?
I think that function took 3 relays.
One to energize the accessory circuit, one to keep it on, and one more to turn it off. There's a few different ways depending on what buttons you wannt controlling it.
