Exhaust Heat Shields
Old Jun 16, 2005 | 05:31 PM
eric_daniel's Avatar
eric_daniel
Default Exhaust Heat Shields
So will I burn up if I take them off? They are rattling horribly!!!! Is there a way to quiet them up other than taking them off??? Could I take them off and wrap the pipes? Just a question...
Old Jun 16, 2005 | 06:02 PM
AZC4Guy's Avatar
AZC4Guy
I've been told the temp will rise significantly under the hood if you do this. My heads have what look like sheet metal screws that hold the two sides together. Do your have those? Have you tightened them?
Old Jun 16, 2005 | 07:19 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
If you tighten them up, they shouldn't rattle
you may need to get the car up in the air to do this
Heat shields protect brake fluid and fuel lines from excess heat
Might be pretty difficult to successfully wrap manifolds
Like someone else said, check the screws. I actually installed stainlees nuts bolts and lock washers to keep them tight
seeya
Old Jun 16, 2005 | 07:23 PM
65Z01's Avatar
65Z01
If they're rattling maybe they are bent and touching where they shouldn't.
Take them off, straighten any deformed metal, fix any deformed screw holes and install them again.
To Exhaust Heat Shields
