What is the general consensus on the best dual mass setup out there right now? I'm running an aluminum flywheel single mass setup right now on my 396 ci LT4 but not that happy with its street manners.
Are there any good hybrid systems out there that offer less weight and good hookup but with the good street manners of a dual mass setup. Don't really want to go back to stock.
Been thru alot of clutches the past five years with my 396. The current set up is the best. Its a SMF set up with very little noise at all. Feels and sounds like the original DMF/Grabs hard at track:
Camaro LT-1 steel flywheel: Shaved .100 (20LBS)
Mcleod Corvette LT-1 Pressure plate
Mcleod Camaro LT-1 Stage 4 disc-- Bronze pucks on both sides-
called the Aussie clutch in the C5's. One step below dual disc.
Idle set at 950 RPM's.
I too have been looking to upgrade my clutch. But I have heard the noise from a single mass setup is unbearable (especially for a street car, which mine is).
But maybe I will try Red Rocket's setup.
Red Rocket, is the noise really bearable at idle and in neutral?
I admit the noise from my single mass setup is loud, but really annoying only while in neutral with the clutch out. Sounds like a metal box with a bunch of rocks bouncing around inside it.
But I was prepared for the noise and can deal with it. Heck, you can just keep your foot in the clutch at stoplights if it bothers ya that much.
Its the DRIVEABILITY factor that bothers me more. I don't know how much is related to the clutch setup or my aluminum flywheel, but I don't like the clutch chatter (judder) and the fact that it is impossible to get smooth takeoffs from a standing stop in traffic at low RPM. You must wind it up to about 2K and release the clutch quickly to get underway. Do you think that is due to the lower mass of the aluminum flywheel (less inertia) or the Stage 2 clutch? That's assuming there was nothing wrong with the initial install, of course.
Until I read your post I thought I only had to worry about noise. Now that I realize driveability is also an issue, I think I will stick with a DM setup until I can afford (sigh...) a 396 SC.
To be honest, I just do not have enough experience to of much help to you. Hopefully others will chime in. Although, it does sound like Red Rocket has tried a number of setups and likes the one he recommended above.
For what its worth, I have heard, if you got the money, the McLeod Street Twin is the best clutch on the market.
The car pulls away real smooth with no chatter or noise at low RPM's.
The noise is really non existent in my 396. Idle and neutal is almost like stock. Did have the whole set up balanced when I put in a new Camaro flywheel this last time. Not sure if this make a big difference. This set up is the quietest of all my previous clutches and grabs hard at the track.
What happened with the stock thickness Camaro flywheel and the modified throwout bearing setup?
Red, the Camaro flywheel setup sounds interesting and a good compromise between a heavy steel flywheel and an aluminum unit. I'm beginning to think that good street driveability may be impossible with an aluminum job.
Is there anything wrong with the full the McLeod Street Twin setup (other than cost)?
Started banging at the track with the clutch pedal on the floor after getting on it. Must have been a clearance issue. Lasted two months with this set up. Do not recommend this approach. Sounds good that you use the factory Camaro flywheel with no shaving but it did not work.
The Street Twin is a great clutch. A little pricey but alot of guys are happy with it.
Bottom line- If your car is a high horsepower/torque stroker that spends alot of time at the track, you will break something on a regular basis with this clutch.
No Drivability issue with Fidanza flywheel and Stage 2 clutch
I replaced my dual mass with Fidanza flywheel and stage 2 clutch from Carolina clutch. I have been driving it for 8 months. The drivability and start from stop is no problem whatsoever. No higher RPM and no slipping of the clutch to get started. It is very similar to the dual mass and definitely picks up RPM quicker. The downside is the gear rattle in neutral as well as the clutch spring resonance between 1 and 2K RPM under moderate to heavy acceleration. Don't hear it in 6th though.
Reason: spelling
This assessment very much describes my experience with the Fidanza/Stage II setup. I have the "black tag" early ZF. In my case I wasn't prepared for so much clattering noise. This absolutely sucked for a daily driver; in fact it was downright embarrassing, at least for me. And I agree, driveability for the street left much to be desired. I lost too much of the old feeling -- the slingshot effect from a dead stop if you will -- and this was a killer. As stated, you had to rev it to about 2,000 rpms from a stop every damn time; this is NO fun. I drove around for several months with this setup and have had it yanked forever in favor of a brand new stock DM setup, and all the fun has returned. I HATED my ultra-light Fidanza compared to the stock (Luk) dual mass flywheel.
Thanks for the update. I was considering going that route.
