I bled the clutch today because I am having some engagement issues. Or rather DIS-engagement issues. Sometimes I have to double clutch it to shift gears. Thought it might be air in the lines, but nada. Part of the problem I think is that the clutch grabs right off the floor. VERY little if any movement before it grabs.
One thing to note: In my rebuild, I switched to a center force dual friction clutch.
Anyway, I noticed as I was taking the slave cylinder off I noticed that if I push the plunger on the slave cylinder all the way in, I can litterally remove the rod between the plunger and the clutch lever.
Should I try a longer rod? (Sorry for the non-technical terms, I am a tinkerer not a trained mechanic.)
