which order for intake installation '88
Old Jun 21, 2005 | 04:20 PM
brookman's Avatar
brookman
Default which order for intake installation '88
I am doing a head gasket job on my '88 and the runner/fuel rail thing seems like a chicken or egg - which came first deal. The stupid reverse bolt on the inside under the fuel pressure regulator. What is the correct installation order?
I will post pictures for those that are interrested - when I am finished
Old Jun 21, 2005 | 04:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
After the intake base is installed, torqued to spec, allowed to stand for >24hrs and then retorqued, the fuel rail and fuel lines go on next.
Then comes the runners and lower runner bolts. I use a magnetic wand to start the tough ones, like the inside one near the FPR. Then a ball driver can be used to run it in till snub, followed up by a Torx bit on an extension & swivel.
Start all bolts well by hand before putting a wrench to any of them and watch that the lower gaskets stay in proper position while installing all the bolts.
Old Jun 21, 2005 | 06:46 PM
brookman's Avatar
brookman
Thanks.
Old Jun 22, 2005 | 12:04 PM
Bottleneckblues's Avatar
Bottleneckblues
One thing to consider is replacing your Torx bolts with hex head bolts.
After having to drill a few of the Torx heads off after stripping, I went on line and replaced all the top end bolts.
Now I'm not cringing as I'm tightening. Top end on mine has been done 3 times. JAT
Old Jun 25, 2005 | 04:30 PM
brookman's Avatar
brookman
You aren't kidding. I went to coopperstate nut and bolt and got some allen head bolts. sure enough I found out why the Previous owner stripped the one that I had to drill out. What do the bolts look like that you used?
The ones I used are very similar but they use an allen key instead of a torx.
To which order for intake installation '88
