High Idle
Old Jun 22, 2005 | 11:03 AM
1986coupe's Avatar
1986coupe
Default High Idle
I thought that I had my idle problems solved but apparently not. I set the timing, replaced the Coolant Sensor, adjusted the TPS, and everything was running fine. Now that the summer weather is here the car idles at around 1,100 rpm. A few days ago when it was cooler outside it ran fine. Any ideas or recommendations?
Old Jun 22, 2005 | 11:40 AM
vader86's Avatar
vader86
Have you checked for vacuum leaks, any codes, or cleaned the IAC?
Old Jun 22, 2005 | 11:47 AM
1986coupe's Avatar
1986coupe
Default High Idle
New IAC, no codes, new vaccuum lines but I will check them again.
Old Jun 23, 2005 | 02:01 AM
jan-erik's Avatar
jan-erik
Hi.
I have an 85 and had problems with the idle. High idle may very well be a vacuum leak. With a vacuum leak you also may have a cycling idle. I had vacuum leakage in the vacuum lines under the plenum and also the runners at where the runners are fixed to the intake manifold. I diagnosed it with some start gas. You might use propane to spray it over the runner/manifold. If the rpm increases then you have a leakage. Have you checked the vacuum lines to the purge in front of the car Black box on the left side in front of the wheel well.
To High Idle
