Rear Spring Codes? help with de-coding
Old Jun 23, 2005 | 05:37 PM
NASCAR314's Avatar
NASCAR314
Default Rear Spring Codes? help with de-coding
They used a 3 letter code on the rear springs for differnt spring rates, it is stamped near one end on the side facing the pavement.
In 1984, they had two available, the FE1, and the Z51
Which one is coded with "BMF" ???
Old Jun 23, 2005 | 08:12 PM
shotchkiss's Avatar
shotchkiss
BMF = base
BMH = HD, which I think would be the Z51
Old Jun 23, 2005 | 08:37 PM
CFI-EFI's Avatar
CFI-EFI
The 1984 Corvette was available with 2 different rear springs. The standard equipment spring was coded, "BMF" and carried part number, 14045785. The "heavy duty" suspension was RPO "FE7". The FE7 suspension was a component of the Z51 handling package. The FE7 rear spring had code, "BMH" and carried part number 14045786.
RACE ON!!!
Old Jun 23, 2005 | 10:02 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
BMF = FE1 72.0 rate
BMH = FE7 87.5 rate
Old Jun 23, 2005 | 10:14 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
'85 Z51 rear spring = NYU 005875
Old Jun 24, 2005 | 11:56 AM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by Z-07 freak
BMF = FE1 72.0 rate
BMH = FE7 87.5 rate
I'm not sure where that info came from. My 1984 Corvette Specifications Manual shows a little differently. The spring rate for the standard equipment rear spring is listed at 75.5 N/mm (Newtons per millimeter) or 431.0 lb/in. (pounds per inch). The FE7 spring is rated at, 91.8 N/mm or 525.0 lb/in. I also show the effective spring rate at the wheel, for anyone interested.
RACE ON!!!
Old Jun 24, 2005 | 05:10 PM
NASCAR314's Avatar
NASCAR314
Default How do you find this information?
Thanks for the replies, my 1st question has been answered!
Where would one find this information? I am aware of Hib Halversons chart elsewhere on the internet, BUT, if you are just looking at a spring, with a code and date of manufacture sticker, how do you know the spring rate?
NEXT QUESTION: Front Spring from a 1989, letter code stamped on it is "FHC" What is the spring rate? I do not know if it is from a FE1 car or an FE7 car
Old Jun 24, 2005 | 07:09 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by NASCAR314
Where would one find this information? BUT, if you are just looking at a spring, with a code and date of manufacture sticker, how do you know the spring rate?
To get the part number, I went to my Corvette Parts Book. As I posted, I got the spring rates from my "1984 Corvette Specifications Manual"
1988-89, Y67 (convertible) with (for 1989) FE1, soft ride suspension, part number, 10048574. I don't have the spec manual for the 1988-1990's and therefore don't have the spring rates.
RACE ON!!!
Old Jun 24, 2005 | 08:47 PM
shotchkiss's Avatar
shotchkiss
Look at the website TravisD made http://www.tubas.net/vette/index.html about halfway down the page in the section Vette Tech Items, he has scanned in the Parts Fiches for the springs.
Old Jun 24, 2005 | 10:37 PM
Z-07 freak's Avatar
Z-07 freak
FHC = front spring for;
1)`88-`91 FE1 convertibles
2) `90 & `91 FE1 w/ FX3 convertibles
3) `88 Z-52 verts
93.1 N/mm rate.
To Rear Spring Codes? help with de-coding
