How extensive is the Optispark failure rate?
I have to wonder how many perfectly good optisparks found their way to the landfill due to mis-diagnosis.
The optispark distributor is a durable sealed unit. Yes, with the '92-'93 they discovered a design flaw. The major flaw they discovered was not moisture related, as many think is the cause of most opti problems, but the fact that the gases created by the spark couldn't escape fast enough. The acidic gases cause corrosion. First they addressed this by moving the vent holes. Then in late '94, they introduced the vacuum vented opti.
I have the original optispark on my '96. Thus far, it has endured an upper radiator hose burst, a radiator leak, a heater hose control valve burst (twice), a lower hose coming off the radiator, and 160K+ miles. In all of those miles, I have replaced just about every supporting part around the opti, icm, coil, various sensors, plugs, wires multiple times, with only the cap and rotor being replaced when the hotcam went in, and even then, the old stuff was still good.
The optispark was also put in Buicks, Cadillacs, Caprice, Camaro, Firebirds, and a few others I think. We're talking police cars, taxi cabs, daily drivers of all sorts. It was the most effective and most efficient distributor of it's time until the coil on plug system was developed.
The problem is, everytime an LT1 has a misfire, or hiccup of any kind, the first thing people do is replace the opti, why? I couldn't tell you. Sure they go bad, but probably not even close to the rate they are replaced due to mis-diagnosis.
...WW
